set back pump transom plates
Results 1 to 7 of 7
    Mar 2011
    Default set back pump transom plates
    just wondering on what it would cost to get them made and where can i get them from.
    Member bubbledeck55's Avatar
    Oct 2010
    bullshit city az
    you could go to a machine shop and have them make up a template or do it yourself and have them cut up a piece of aluminum for ya into two pieces..
    These are typically "fabricated" to the individual boat as each set is /can be slightly different and the tolerances (clearance) between the inner edges are critical to good sealing Typically you could mock them up with graph paper and cardboard or masonitle then band saw them out of either Aluminum stock or even fiberglass sheeting Call if you need Tech help Tom
    heres a couple examples Josh has done recently for you
    Mar 2011
    Just curious as to what this is for.. cause my dad had a 3foot by 2 foot sheet of pretty thick aluminum and i have no idea what it was for. could be this or something for his bike..
    Ladera Ranch
    I have a few that I have made that would save you some time if your hand hole will be outside the boat. One is 1/4 inch, the other is 3/8. They fit my berk well. Pm for details.
    Senior Member junkyard's Avatar
    PHX AZ
    You can also go this rout. I have the aluminum set back cover for sale in parts spam.
ID:	110195   Click image for larger version.
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    Get yourself some cardboard and start trimming. Then transfer to some plate.
    Someone on here did the small round rods laid out that would adjust to the contour. . It was pretty awesome.
    QE 439 Twin Turbo
