Quick question about MSD wire hookup
Results 1 to 9 of 9
    "Floatin' Motor" BoNeS's Avatar
    Jun 2010
    Surprise, AZ
    Default Quick question about MSD wire hookup
    I'm trying to figure out if i'm understanding the diagram correctly, the white wire hookup is confusing me a bit. The diagram says to hookup to the negative wire of the output of points or electronic ignition amplifier, so is that the negative wire of the module inside the distributor?? Cuz if it is, that's connected to the coil and that's not making sense to me. For the love of god, i hate wiring!!
    More info needed
    Which distributor are you using
    The white wire is used only on some apps
    Sent from my iPhone
    #55
    Jun 2010
    Surprise, AZ
    More info needed
    Sent from my iPhone
    Mallory distributor, the MSD is MSD 6A/6200
    Jun 2010
    Surprise, AZ
    I just need to verify if i need to disconnect the negative (from the module in the distributor) from the coil and connect it to the white wire from the MSD box.
    Senior Member slotracer's Avatar
    what mallory is it? if your running points you use it, if your running magnetic pick up you do not use it.
    slot
    87 eliminator
    next boat ??????????????
    new owner of the redneck yacht club
    Stockton, ca.
    #55
    Jun 2010
    Surprise, AZ
    Quote Originally Posted by slotracer View Post
    It's a Mallory Unilite distributor. I have 3 wires that come off the distributor, red, green and brown. The red(+) and green(-) connect to the coil and the brown connects to the termial block. I know that using the MSD you connect their (+) and (-) wires to the coil and those are the only wires that are supposed to be connected to the coil. So that means the (+) from my distributor connect to the MSD small red (+) wire and the green (-) wire from the distributor connects to the white on the MSD...right??
    Boat Bling Distributor blackbart's Avatar
    just put one in last summer msd ,, had 3 wire as i rember and the drawing that came with it was wroung white is ground big lug ,,, red to postiev coil and brown to key hot
    as my memory humm
    Moabi before the invasion!!!!!!!!!
    Jun 2010
    Surprise, AZ
    Thx guys, i got it.
