went out yesterday and something came apart
Results 1 to 13 of 13
    Junior Member ICEDITTER's Avatar
    Mar 2011
    Default went out yesterday and something came apart
    was running dead lake yesterday afternoon took a sharp left and something came loose will post pics as soon as i get it torn down oh the fun the guy i bought it from short cut on the oilpan its a stock bbc truck pan it will have all the correct stuff after this
    Mar 2011
    got it torn down # 3 piston shattered crank broken in half between 3&4 will post some great pics tonight after i get heads off its pretty amazing the damage 6000 rpm can produce......all i can do is laugh hope the cam & heads are ok
    Menominee, mi UP
    Aug 2009
    Menominee, mi
    thats a huge bummer
    Southwest corner AR
    Quote Originally Posted by ICEDITTER View Post
    If a rod broke cam and block will probley be toast too! Hate to here the bad luck!
    WT
    WFL Crew!!!
    Pink Taco Reagan's Avatar
    Santa Clarita, California, United States
    That sucks, however on the bright side time to upgrade
    Mar 2011
    Rod is completely intact pistion is in oil pan called parts house looking for a 2 piece crankshaft roflmao found a 502 shortblock that needs rebuild 700.00 great starting point going to pick up sunday morning
    Mar 2011
    Default Pics are up in my albums super sweet damage/
    Check out the cracked crank and no piston left has a huge crack in the cylinder wall too
    Salem,Or
    so what do you think caused that carnage?
    With Spray there is a way!!!
    Mar 2011
    I believe the crankshaft snapped but cant prove it, curious will my heads bolt on a 502 block they are 73 oval ports got lots tied up in them
    Mar 2011
    Wow i have a 3 piece crankshaft
    Senior Member coonass's Avatar
    Canyon Lake, TX
    got a 496 block and crank in south texas for ya pm if interested
    thats a bummer
    WFLC
    Mar 2011
    Default Block
    Hell yeah call me 251-391-4362 im dennis
    Menifee
    If you go bigger cubes I'd seriously consider getting a set of real cylinder heads for it. I know the aftermarket square ports might be out of range if you are on a budget however at the very least grab a set of 990's........
    Keith...
