How important is the little scoop opening on the engine cover
Results 1 to 5 of 5
    Senior Member mesquito_creek's Avatar
    Chandler
    Default How important is the little scoop opening on the engine cover
    I am redoing the engine cover and I am converting an engine box with a little scoop to a deck lid type cover... Is there enough airflow through the side vent and what can move in from around the rear seat etc to eliminate the little scoop .... Its a stock 355 280 hp with a volvo outdrive..
    1993 Malibu Fllightcraft, 20 foot, Merc 200Xri
    1982 Sleekcraft Ambassador, 26 foot, Chevy 350/VolvoPenta
    Oct 2010
    661 So. Cal.
    Quote Originally Posted by mesquito_creek View Post
    OUTDRIVE? what is this you speak of
    Should be plenty, make sure the bilge is vented properly, and you have a functioning bilge blower.
    I converted my dog house into a full hatch. Your hull looks to be deep enough to rid the scoop. I made one to fit around my flame arrestor.
    Made In The Shade
    Custom Window Tinting
    Yucaipa, California
    I had a 21' jet and i converted from that doghouse to a solid swim bench/engine hatch with no holes in it whatsoever. The side vent was plenty of air for it, also there's gaps between the side panels and bottom of the rear seats in my setup which would let air in too. I only ran a stock m otor though. Just remember more than anything to run that bilge blower when proper, I used to just get in the habit of opening the hatch for a few before i fired it the first time.
    Also, you will love how much quieter the motor is at idle and while cruising with no scoop on it. Night and day difference.
    1992 Eliminator Daytona 21'
