What is the best way............
Results 1 to 14 of 24
    " Live Laterally " Dominator's Avatar
    Phoenix
    Default What is the best way............
    Have a 21' tunnel with a motor in it and I need to get if off the trailer to paint the trailer. What is the best way to get it off do so? I have access to big equipment.
    " NO MOTOR NO BOATER "
    " I'd rather be riding in my boat thinking about God, than in church thinking about my boat ".
    Oct 2010
    661 So. Cal.
    Quote Originally Posted by Dominator View Post
    If you have access to big equipment then use it. if it were me I would use a crane with two straps(slings) one at the bow through the bow eye ant one at the back, just ahead of the intake, using the intake fins as a stop to keep the strap from sliding of.
    Well you go to the lake. Have someone back you in.Thennn tell them to go paint the trailer and comeback. If they did a good job you will give them a ride.
    Or do like I have done. I have a automotive hoist. Pull the trailer in and use 2 straps and lift the hoist and drive trailer out. Know a guy who uses a large A-frame.
    Two shop cranes have always worked well for me
    Phoenix
    My question is it to heavy to lift like that? I have done plenty of 19' that way but its 21' Liberator and seems really heavy. Its my Dads boat so don't want to damage it. Do I put the straps horizontal or parallel? Like long wise or width wise?
    Phoenix
    Tom, the boat I need to get off the trailer has a pump and a motor in it. Thats why I am concerned.
    Team CJ460 Just Electric's Avatar
    granada hills
    even easier put a lifting strap on the pump and throught the bow hook and done
    if u have access to to engine hoist im sure between u josh and ur da u do
    Trick Flow 557 BLUE OVAL CP's Avatar
    Lomita, CA
    How is the picker hooked up in the front of this pic? Looks like a good easy way to flip a heavier boat.
    Phoenix
    Quote Originally Posted by Just Electric View Post
    Yes between us 3 I do. However Im bringing up her to Colorado and my buddies shop is next door to SWAG (big equipment Kuboat dealer) and the owner lets use whatever we need when we need it in trade for beer and bench racing around the boats.
    granada hills
    nice then use a gradall
    Ada, Michigan
    You can do the whole job with no heavy equipment.
    Just the trailer tongue jack and some wood blocks.
    1) Crank the jack down as far as it will go, stack up some large wood blocks under the transom just past the last trailer crossmember.
    2) Crank the jack up to well above level and stack another block pile under either side of the keel to support the front of the boat.
    3) Let the jack down and the boat will now be sitting on the blocks and the trailer will be loose.
    As you roll the trailer forward you will have to put a floor jack under the keel a couple times to release and change the blocks as you come up against a trailer crossmember.
    Of course you want to protect the bottom of the boat from the jack plate with a piece of plywood or heavy carpet.
    Use some common sense and it works fine.
    The Man cordog009's Avatar
    East Texas
    That sounds like a good way to do it. Spraying the carpet on the trailer bunks with some water will help it slide off.
    1984 Youngblood TX-19 SOLD
    Phoenix
    Common sense i have a little bit of. Thanks I just might try that.
    Thank you as well. As of now I think we just may use the lift in the shop.
    Senior Member cave's Avatar
    Mesa, AZ
    Hey Dom, Unstrap the boat from the trailer then Hit it. oat will come right off. If that dont worky take the boat to the nearest watering hole dip it in then Do the above again.
    5 more days sucka
    Takin it home
