bulkhead and pump questions
Results 1 to 3 of 3
    Mar 2011
    Default bulkhead and pump questions
    hey guys what wood do i need to use for the bulkhead? go my intake gasket and need to know what type of screws do i need to attach pump to intake.
    dont understand wood to bulkhead? suction housing to intake uses 5/16 nc bolts. bearing cap to suction 5/16 nc socket head. suction to bowl 1/2nc. bowl to nozzle housing or droop snoot 5/16 nc, hope this helps
    I have reg plywood sealed in fiber/resin and if you add surface seal to the "clear resin" it will dry to a nice smooth finish....Learned that trick on my surfboards.
    Made In The Shade
    Custom Window Tinting
