Berk suction housing needed
Results 1 to 10 of 10
    Default Berk suction housing needed
    anyone got a good one? i'm looking for a late model one, hopefully without a bunch of core shift. thanks.
    Is it the weight difference, that makes you want the Berk housing? The Dominator suction is a nice piece, with extra rib I guess it would a little task to re-rigg for a different brand suction.
    Ya I posted that because its what i have now. CS said the same thing. I"ve cracked two Berks so I better go with the stronger one. So, anyone got a late-model dominator suction housing? i'll make a new set of TA plates and upgrade to that one.
    1977 Custom Sprint Jet wickedsanger's Avatar
    Irmo S.C.
    Post
    What do you think is causing the berk suction piece to break??? Would you mind showing me a pic of your pump braces?? Just curious.. Thanks!!
    Wickedsanger... Gettin it done with a Small Block!!!!
    B1 Racing cs19's Avatar
    The aluminum around the bearing cavity is trying to tear off the suction housing, it happens to every single race boat running a berkeley housing over time if they are running any kind of significant horsepower. Get a dominator and find something else to worry about, thats what I did anyways.
    Shell Knob, MO
    Cyclone, check your PM.
    Duane HTP
    Senior Member Sweet Pickle's Avatar
    Mar 2011
    Calimesa CA
    Hey Chris, How often do you recommend rebuilding a pump to check for such things?
    Senior Member APOLLO's Avatar
    MAHTOMEDI,MN
    This is what mine looked like last summer.
Name:	broken jet pump 003.jpg
ID:	111340   Click image for larger version.
Name:	broken jet pump 007.jpg
ID:	111341   Click image for larger version.
Name:	broken jet pump 001.jpg
    Quote Originally Posted by APOLLO View Post
    That sux but atleast it broke outside the boat. The few I've seen haven't been that fortunate.
    Senior Member PCE680's Avatar
    Manhattan Beach,CA / LHC,AZ
