First day out with new heads/cam....but I am concerned about something.
Results 1 to 14 of 38
    Senior Member jet460's Avatar
    Mar 2010
    Modesto, Ca.
    Default First day out with new heads/cam....but I am concerned about something.
    Took the boat out for the first drive since swapping out the old D2VE heads for DOVE-C's and putting in the new Comp cam. I also added roller rockers, a 10qt pan and the Milodon oil pump/pickup.
    After running the boat in the water, on the trailer for well over 30 minutes to break in the cam, changing the oil filter, and some putt-putt around the lake for a while, I decided to see what it could do.
    Well, she screams pretty good, as you can see from the short vid.
    Night vs day from the old heads.
    This motor hits 5000 rpm's in an instant.
    I don't think the top speed will be much more than before, but it gets there a LOT faster.
    My pair of Holly 450's seem pretty much maxed out, so maybe an upgrade is in order when funds are available.
    One thing does concern me greatly though...
    I have a mechanical oil pressure gauge on the back of the block, as well as an electrical gauge on the dash.
    Both were pegged at 100psi when I gunned it.
    Back down to maybe 60psi when idling.
    This cannot be normal, can it?
    Nothing was done with the stock block other than a new timing chain and the new oil pump and pan.
    Not sure if I should be worried, but I am anyway.
    100psi seems ridiculously high to me.
    100 years from now, none of this will matter.
    Senior Member HotRodJosh's Avatar
    Oct 2010
    Spanaway, Washington
    That is a tad high....so no bearings were replaced?
    I take it the new oil pump is a high pressure pump? Or high volume?? What temp is engine at?
    My 440 in the Charger runs at 80 psi when cold....75 when warmed up and 60 at idle...been that way for 10 years without any ill effects.
    Mar 2010
    Modesto, Ca.
    Quote Originally Posted by HotRodJosh View Post
    Didn't replace any bearings.
    The pump is just standard volume and pressure.
    The oil in there is Valvoline 20w-50 racing oil.
    Temp is normal. No stat, so it varies from 130-160ish depending on what I am doing.
    Mar 2010
    Modesto, Ca.
    Maybe I spun a bearing? Doesn't sound like it. Boat runs extremely strong.
    Sounds like you need to come up to CFW Saturday.
    San Diego, CA
    you're probably fine. if you spun a bearing you'd have low pressure problems.
    All the 100psi is doing is robbing hp to turn that new oil pump
    Boat 405.
    Mar 2010
    Modesto, Ca.
    I would LOVE to, but I have to work Saturdays.
    Mar 2010
    Modesto, Ca.
    Yeah, I am hoping that is all it is. I freakin' love the way this thing runs.
    Senior Member Scapegoat's Avatar
    SoCal
    Too high of oil pressure will wear out the bearings babbitt quick. I would lower your oil weight and see if it continues. Most likely cause is the oil pump since you replaced it. It could also be from the new cam and bearings having a tight tolerence. Oil pump Relief valve is not letting oil bypass untill predetermined pressure. In your case it is pretty high. A spring change in the pump could change this. I'm not sure whats considered excessive but 100 seems high.
    High pressure from the pump can or will cause endplay on the cam. Parts could fail due to excessive stress. Play it safe and call a couple shops like BD marine or Clay Smith cams.
    San Francisco Bay Area
    Cool
    Quote Originally Posted by jet460 View Post
    Back down to maybe 60psi when idlinng.
    Your post states, "putting in the new...10qt pan and the Milodon oil pump/pickup."
    That sounds like you changed the oil pump. Did you change the pump or not? If so, then what is the model of the pump that came out and what is the model of the pump that went in?
    100 psi is way too much for your application, for several reasons.
    Paul
    High Flow Dynamics
    Mar 2010
    Modesto, Ca.
    Quote Originally Posted by LakesOnly View Post
    Paul
    Yes, I changed the oil pump and pickup as well as the pan.
    I put on a Milodon 10qt pan.
    MEL-M84DHV is the part # for the pump
    It had a stock 5 qt pan and truck type pump.
    Cool
    The M84DHV is a High Volume oil pump, not standard volume as you originally thought.
    Even if you have a bone stock 460 with OEM passenger car clearances the pressure seems higher than typical. Assuming the bypass piston isn't stuck (and I kinda doubt that it is, based on your overall idle/5000 rpm pressure behavior) then you ought to switch to a 10W-30 engine oil in an effort to reduce your oil pressure.
    LO
    High Flow Dynamics
    Thumbs up
    Sounds nice. It's amazing how a set of ported D0VEs can transform these engines, isn't it?
    High Flow Dynamics
    Mar 2010
    Modesto, Ca.
    LO
    I honestly don't remember ordering a HV pump.
    Didn't want one, but that's what I got.
    I've only run it once, so I will keep a close eye and probably switch to a lighter weight if it doesn't drop some.
    Thanks Paul.
