Jetaway Question
Jetaway Question
    Senior Member XClutchboy725's Avatar
    Alta Loma, CA
    Default Jetaway Question
    Will the Hi-Tech Performance Jetaway fit an AT-309 American Turbine pump?
    I only see 4 bolts on my input bearing collar, and the Jetaway appears to have 8. Would I only use 4?
    Led
    Led is offline
    Senior Member Led's Avatar
    Jul 2010
    they recommend that you drill and tap the other holes.
    Alta Loma, CA
    That makes sense! Just like a racecar, nothing ever bolts up to these things....Thanks
    Senior Member Alter Ego's Avatar
    Jun 2010
    South Arkansas
    If it all just bolted right up, you wouldnt have a winter project...i just went through this, had to pull finally got it all finished now, and had to move the motor. I know it is going to be more than worth the effort.
