Repairing intake fins
Results 1 to 14 of 14
    Senior Member bc18's Avatar
    Default Repairing intake fins
    Working on our eliminator and just wondering how do you go about repairing these? They are cast aluminum and pretty beat up so can I weld another piece on it and shape it or is there another way to repair these?
    Senior Member Futs's Avatar
    Orange CA, Big River
    Quote Originally Posted by bc18 View Post
    Take a picture Brad. If its not to bad you can reshape them or cut them down. You can weld them up, but i wouldnt suggest doing that in the boat.
    Senior Member Alter Ego's Avatar
    Jun 2010
    South Arkansas
    The fin on the drivers side of the intake on my boat has about two to three inches that have been broken off. Looks like one of the previous owners simply reshaped it, and let it bump. It has not seemed to negatively impact the loading, handling, performance of the boat, just ugly when you see them not matching when you look underneath the boat.
    you can see in the front where its been broken on both sides then repaired. i dont know if you can still repair the one side by grinding and reshaping but if your guys still think i can then ill go that route
    Yucaipa Ca
    I would replace the intake.... Just my 0.02!
    460 is offline
    ATTA BOY 460's Avatar
    Ummmm i would get a new intake. That is ruined in my eyes. Just saying
    Oct 2010
    661 So. Cal.
    Yeah replace it. that thing is done
    Wet
    Wet is offline
    East Hampton, CT
    Grind them both flat and see what that does for the boat.
    Oct 2010
    661 So. Cal.
    Quote Originally Posted by Wet View Post
    spin out madness, and possibiltiy of unloading the pump, spinning the motor to a million RPM's and catastrophic failure. Meh whats the worst that could happen
    Wet
    Wet is offline
    East Hampton, CT
    Sorry, but those fins don't do shit for loading the pump.
    987
    987 is offline
    SWDBA 987's Avatar
    Aug 2010
    Rio Rancho, NM
    Don't do it........you need them to drive against.....I had to replace the intake on my winter project because the fins were missing and I was told it had control issues.....wasn't going to chance not being able to control it........Replace the intake!!!!!
    96' 18ft Pantera Drag Boat
    Member Katanna's Avatar
    Jun 2010
    Howell Mi.
    Default ouch
    might want to check the trailer first. Are the bunks too low causing it to drag across the rear frame member on shallow ramps?
    Avondale,AZ.
    Some boats the fins have no discernable effect at all(think "E" pump- NO FINS), others will have load issues, especially in the corners, the higher the Horsepower usally determines the grief, as does hull design. I have a bunch of the intakes for sale cheap! TIMINATOR
    Wet
    Wet is offline
    East Hampton, CT
    I found that the fins created more turbulence/cavitation when making extremely tight corners on my V-hull. Those tight corners are nearly impossible on the tunnel, which makes me wonder about the necessity of fins to maintain tracking on the tunnel? Food for thought.
