Say guys....how "flat" should the bottom of the hull be from transom towars keel?
I know there will be a difference between hulls, however is there a "minimum"???
My Makai is flat up until the 1/4 stringers end, then slightly tapers up....
Either it's correct or the engine is "sagging" that area....and before I go glassing in new stringers, want to make sure all is well...
Thanks in advance!
