Berkeley Pump ID 12JCA-H
Results 1 to 2 of 2
    "Mad" Member Jet Mad's Avatar
    Cape Town, South Africa
    Default Berkeley Pump ID 12JCA-H
    I recently purchased a 12JC Berkeley pump, stamped on the ID plate 12JCA-H.
    I think the A stands for the impeller "A" that was factory fitted, but the "H" I don't know.
    It is extremely rare to find Berkeley pumps for sale in South Africa, this one even has a Jet-O-Vator fitted, which makes it even more of a good find for me.
    I will be using this pump as a back up or if I find a nice hull......
    Does the "H" stand for something specific?
    Wikus
    How do you install the intake different from the correct way - assuming you install the intake as per Berkeley Jet specs. Has anybody seen a heavy duty install with angled head bolts?
    I am going to install the pump in a new hull - Similar to "Eliminator" hull that is build locally by a boat builder here in South Africa.
    Below is the reply from Berkeley Jet.
    Wikus,
    The H was for how the intake was installed in the boat. The pump kit came with carrage type bolts that had angled heads . It was ment to be a heavy duty installation.
    Rick
