Yeah, I'm anal
Results 1 to 12 of 12
Yeah, I'm anal
    Lake Havasu
    Default Yeah, I'm anal
    I picked up my new popoff from John Mills last night for my placecraft, nice guy! Anyway, it is anodized black. I really want it to match either the pump (grey), or the rigging in the boat (blue). So I'm thinking I'll powdercoat it. Anyone ever powdercoat a popoff before?
    Southwest corner AR
    What about reanodize it to the color you want? PC is thick and I wonder if it could cause problems! Im just sayin!
    WT
    WFL Crew!!!
    Lake Havasu
    It's hard anodized. It would need to be stripped to reanodize which would remove the hard anodize. I don't think you can hard anodize in blue, maybe grey? If I powdercoat it would have to be masked on the inside.
    I wouldn't call that ANAL. thats just being thorough
    #55
    Senior Member cripple midget racing's Avatar
    Menifee, Ca.
    I call It Just Being Steve !!!
    Steve you can anodize in blue. The issue maybe matching the blue ano to the blue powder coat you have in the boat. If you do decide to have it anodized blue just make sure they seal the part well so it doesn't fade.
    Ceramachrome it!
    Lake Havasu
    Jordan, I know you can anodize blue. Don't know about "hard anodize" in blue? You're right, blue anodize will not match the blue powdercoat on the rigging. I guess my main concern about the powdercoat is the masking on the inside of the valve, otherwise it's a no brainer.
    Senior Member Red Rocket's Avatar
    winchester, ca
    Whatever you decide to do don't remove the hard ano from the inside of the cylinder.
    You can do a hard blue but its darker in color.
    As far as the powder coat goes you may want to talk to Jeff @ Embee. I can all but guarantee you that he has powder coated a valve or two and at the very least can point you in the right direction. You may also want to find out if the anodized surface gives the desired adhesion characteristics needed for the powder coat to stick or if they are going to have to sand blast it off. My guess is that the anodized surface should be fine if not better due to the superior adhesion characteristics provided by the ano.
    Senior Member tiki's Avatar
    costa mesa ca
    no worries. pull it appart and send it down along with a sample of the blue powder that you want to match(a washer or mount will do). the i.d. will ba masked as the hard coat is a must have in order for the valve to function properly. 714-546-6907
    Lake Havasu
    Quote Originally Posted by tiki View Post
    Great! I'll send it to you on monday..... THANKS
