kill switch
kill switch
    Member TV334's Avatar
    Gillette WY
    Default kill switch
    What do you guys run for kill switches? How do they wire in? All i have is a lake boat so do i really need one? Thanks.
    Senior Member bc18's Avatar
    I ran a mercury kill switch from Rex marine. It's a really good safety feature to have even if it's a lake boat. It's really simple to wire in also, you run it inline with your ignition wire so when the cap is pulled it stops the spark to your motor
    Atlanta, Texas, United States
    Quote Originally Posted by TV334 View Post
    Check this link for various styles: Marine Kill Switches, Mercury: Automotive Performance Products, Boat & Marine Parts & Hardware They should be available from most marine supply companies.
    Typically on a battery ignition, one would place the switch in-line in the power lead from the ignition switch to the ignition box or coil. Magneto styles ground out the mags, etc. I have used both the Mercury style and double ball style with reasonable results. On the double ball, over time you may need to clean the contacts and/or make sure the plastic base does not warp or crack as that may affect the contact pressure and continuity on the switch.
    Definately should be a "have to have one" item on your list.
    Gillette WY
    Sweet guys i'll get one ordered asap thanks for all the help.
