Bassett headers cleaning questions
Results 1 to 9 of 9
    Mar 2011
    Default Bassett headers cleaning questions
    hey all. what do you use to clean the blue off headers and also some light surface rust?
    thanks all!
    Jun 2010
    I used some stuff called Blue Job for the blue sorta works don't get too aggresive... as for cleaning always and only 409 spray period
    Team CJ460 Just Electric's Avatar
    granada hills
    kaboom from oxy clean works pretty good
    Denton, TX
    Metal wax!
    Sent from my iPhone using Tapatalk to hide from the IT dept.
    Senior Member Fonz69's Avatar
    Frozen Tundra, WI
    I used WD40 on them after every time out and it seems to work fine, it does burn off when your running it but spraying down inbetween the tubes helps slow down that rust
    Mar 2010
    Clarksville, TN
    Quote Originally Posted by Fonz69 View Post
    WD40 will turn them yellow if you don't clean it off .. Great for winter storage though
    Member E Rock's Avatar
    Jun 2010
    Tulsa OK
    For light surface rust I use 4 ott steel wool. It's super fine and won't damage the chrome. Works great
    Quote Originally Posted by slam View Post
    x2 just make sure it is 4 ott(oooo) or it will scratch em.
    Frozen Tundra, WI
    Must be a different kind because it never yellowed ever for me
    Sprayed it on after every time out and wiped it down with a WD40 soaked rag and let it sit till it burned off the next time out
