How tight is too tight? Quick impy to wear ring Q?
Results 1 to 5 of 5
    Default How tight is too tight? Quick impy to wear ring Q?
    Long story just went through my jet, time to put the impy in and I would have swore I had heard on here a few weeks prior someone said to set em at 010. Long story short lookin at another wear ring thread on a different board got my curiosity up and the berk manual says .025 - .035. I don't mind pullin it apart no biggie.....but I dont get it....I guess set it that loose cause your thrust bearing is gonna wear that much?
    I would pull it down and add some shim
    Sent from my iPhone
    #55
    "gotta be tight to be good " doesn't apply here Bud , pull it and shim it Tom
    Thanks guys....my bad
    Atlanta, Texas, United States
    When racing and it starts seizing with metal to metal contact, then it is a little too close. Otherwise, on the lake, give it a little clearance. You know there is a lot of sand out there
    Gear
    PS, I set a MSDBA record back in 1986 with a wear ring that was seized to the impeller and spinning in the insulator. The boat ran fast enough for the record and win, but needed a new impeller and wear ring after the race.
