is this right???
Results 1 to 14 of 17
is this right???
    odfirefighter
    Jul 2010
    Default is this right???
    turning 5000 rpm, A impeller, 12jg pump. smooth water, 56MPH GPS!! 18ft sanger super jet, no droop or place diverter. is this right?? or is that about par for the course?
    Sounds about right
    Sent from my iPhone
    #55
    odfirefighter
    Jul 2010
    so what do you guys think would give me the most bang for the buck, a loader a droop or a diverter?
    odfirefighter
    Jul 2010
    would be totaly satisfied with 65 out of this boat, whats the easiest way to get there?
    Impeachment! 75 TX's Avatar
    Culver City, Ca
    Quote Originally Posted by odfirefighter View Post
    All three might get you to 65. If you're at 56 now I seriously doubt any of those items will get you 9mph by itself.
    If you just wanna go incrementally I'd start with the diverter. It'll definetly help.
    Senior Member CP598's Avatar
    Sep 2008
    5000 RPM on a "A" impeller I would think would be more than 56 MPH. My 19 Gullwing ran 80 MPH at 5000 RPM on a "A" impeller, 62 MPH at 4000 RPM. I know you have a different hull but....
    What you didn't include in the equasion is the HP or and estimate of HP or a description of the engine (important when comparing RPMS vs speed vs performance) and also what condition you suspect the jet is currently in. 56 is a little sleepy, would expect a bit more ,not sure the Sanger SJ would like a (mine didn't) droop but a Place diverter will definatley be benificial Tom
    odfirefighter
    Jul 2010
    well motor is 460 .30 over forged srp flat tops, mild port job on a set of d3ve heads, weand stealth intake and a 750 holley, lunati 61602 cam (bout .550 lift) operating range is like 1400-5500 or something like that. just finished building motor, only about 4 hours on it right now. it seems to be running very strong. from very simular setups i have seen and read about im thinking on the 400hp range. it feels very good out of the hole, just seems like it tapers off very quick on top but the motor will still pull a little more rpm with no noticible increase in mph, so i was thinking maybe it was cavatating or something like that, im new to the jet world and dont know alot about this stuff.as far as the condition of the jet i dont know for sure, i got the boat last year and the guy that i got it from said the jet was rebuilt about 2 years ago, not sure i trust that cuz he also said the motor was rebuild and already bored .30 over and it was stock bore and all original internals and bearing. thanks alot for yalls help and input.
    Avondale,AZ.
    Borrow or buy an MSD tach checker first. If that is correct, you have either a pump issue (wear or improper rebuild) or a small ("B") impeller. When the pump was rebuilt is irrelevent, we had a customer destroy his fresh pump in about 4 outings by launching from the beach, and revving the engine to warm it up, in about 3 feet of water. The sand wore out the wear ring and the impeller was worn so bad that it couldn't be turned for an undersized wearring. With a new boat purchase, assume nothing, and believe less. TIMINATOR
    odfirefighter
    Jul 2010
    thanks for the input, so where do you guys think i shud start? impeller/wear ring rebuild? or try a place diverter and loader and see if that helps out? i realy want a diverter either way but i just want this boat running where it should be, just dont know where to start.
    All your numbers look about right but you likley have some more MPH how "wet" does the boat run at speed , if you were to observe from shore where would you say the hull breaks water at WOT eg at the front of the engine , even with the seats ? etc
    odfirefighter
    Jul 2010
    i have been trying to get some picks or video of the boat on the water from the shore. from what i can tell the boat breaks water about midway between the front seats and the motor. but i honestly havent paid that much attention to it. but im pretty sure thats about where it it is. im am taking an 8 day lake trip starting the 30th of this month so im gonna try and get some good picks and video of where its riding.
    Roll under the boat with a camera and take a pic of the jet intake (loader grate if equipt) area also if equipt where the ride plate is set (up or down) versus keel maybe post them up Tom
    NorCal HotBoats Chili's Avatar
    Aug 2009
    Chico / Paradise
    But not at the same time you're trying to see where it breaks water. lol
    74 Belmont - 455 - Berkeley
    Facebook - NorCal - Local Chapter of American Hot Boats
