Raven Tri Hull ?
Results 1 to 3 of 3
Raven Tri Hull ?
    "Mad" Member Jet Mad's Avatar
    Cape Town, South Africa
    Question Raven Tri Hull ?
    I found this Raven Wildcat Tri (ex racing) hull locally and is considering converting it to a jet boat.
    I will be using my 12JC pump with PD and ride plate powered by my 650HP Olds that is currently in my Kona.
    Here are some pics of the hull.
    Any advice will be appreciated.
ID:	113090   Click image for larger version.
ID:	113091   Click image for larger version.
ID:	113092   Click image for larger version.
ID:	113093   Click image for larger version.
    TRG
    TRG is offline
    Senior Member TRG's Avatar
    Looks like an outboard hull.....
    I would get a good measure on keel depth in relation to the sponson depth, your jet will not work too well if the sponsons are too deep.
    Quote Originally Posted by TRG View Post
    TRG,
    Any idea what the measurements should be, I have no clue and the hull is about a 1000miles from where I am.
    How do the I explain to the guy on the other end how to measure the hull. It is at a marine shop, what do I ask him.
    Sorry for the stupid ? but it is the first tri hull I have dealt with.
    Wikus
