<<Water collecting excessivly while boat sits>>
Results 1 to 14 of 24
    "Floatin' Motor" BoNeS's Avatar
    Jun 2010
    Surprise, AZ
    Default <<Water collecting excessivly while boat sits>>
    While i'm hanging out on the shore i seem to be collecting an excessive amount of water in a short time. I have to run the water pump about every hour or so or it fills the entire rear of the boat. If i let it sit overnight without running the pump the entire rear end is filled up, the entire rearend would be sumberged if the shoreline wasn't so level where i beach. What and where do i need to look to see what i need to fix/replace to resolve this issue??
    Certified Wildman! Sanger Flatbottom's Avatar
    May 2010
    Antioch, Calif (NorCal)
    Next time you trailer it, fill the inside with water and look for where it's coming out. Tilt front up with back down to simulate the conditions you have when taking on water. Works every time!
    Everything electrical has smoke in it.... and it's not done till you let the smoke out!
    the real honcho bagged97taco's Avatar
    tucson az
    Default water leak
    My buddies daytona had the same problem. It was coming in from around the transom plates for the pump. Had to rebuild his plates. Problem fixed. Check that out.
    Quote Originally Posted by Sanger Flatbottom View Post
    What a smart idea!
    Jun 2010
    Surprise, AZ
    Crap, why didn't i think of that!?
    May 2010
    Discovery Bay, CA
    How old is the hull? Check the epoxy around the intake to hull area. I had the same problem and found it the same way, water around the intake on the inside and watched under boat for leaks Had to remove intake and reinstalled with new epoxy from CP Marine. worked great
Name:	boat intake.jpg
    Break Out AnotherThousand
    If it's a jet
    Check the packing flange for leaks
    Sent from my iPhone
    #55
    The Good mrjoshua's Avatar
    Aug 2010
    Albuquerque NM
    When i bought mine the previous owner said it was getting a little water in it. Got under the boat and there were "oily" drips and stains on the epoxy. Engine crud mixed with water and seeped thru. Had to reset the intake.
    Senior Member slow67's Avatar
    DFW
    X2 on filling it with water....I had the same problem, then found a cracked strake (crack was hidden by a trailer bunk).
    If it's a jet
    Sent from my iPhone
    X2...if the packing gland is leaking.....the fill it with water on the trailer dealio aint gonna show unless you put ALOT of water in the boat...pretty sure my starter would be under water at that point.
    Oct 2010
    Lake Dallas TX
    Default Joe Pool and THB
    Quote Originally Posted by slow67 View Post
    izzat you Steve ?
    Jun 2010
    Surprise, AZ
    Found the problem......
    Jun 2010
    Castaic
    Holy crap. That's not a slow leak! Good thing you don't fish, you'd be swimin back to the dock.
    May 2010
    Discovery Bay, CA
    Quote Originally Posted by bones View Post
    found the problem......
    holy s#*t!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
