455 olds to 454 BBC
Results 1 to 9 of 9
455 olds to 454 BBC
    Senior Member sleekcraft137's Avatar
    Star, ID
    Default 455 olds to 454 BBC
    I have a chance to get a fresh BBC 454, however i need to sell my olds to do it. Besides the engine plates/bell housing Whatelse do i need??
    Also if anyone is looking for a fresh 455 olds let me know!
    And the new project begins!
    Impeachment! 75 TX's Avatar
    Culver City, Ca
    Quote Originally Posted by sleekcraft137 View Post
    In addition to the parts you mentioned you'll need a PTO and exhaust for the BBC.
    Wet
    Wet is offline
    East Hampton, CT
    Don't let cost keep you from making the switch. You'll love the change and it's really easier than you think.
    Shell Knob, MO
    I have a set of used log manifolds for sale for a BBC for
    $150.00.
    Duane HTP
    Star, ID
    $150.00.
    Duane HTP
    i have a pto and exhaust........so i guess im good.
    Star, ID
    so i will be running a stock 454 4bolt main, with a torker II and a predator carb. im running an A impeller and a place diverter. What type of RMP's/Speeds are being seen with this combo? i know its stock etc. but i was just curious
    Woodstock, IL.
    With a tight pump and new impellor I would say around 4500-4600 depending on the cam.
    If the pump slips you could see more but might not get top speeds.
    The government's monetary role is to maintain the integrity of the monetary unit, not participate in fraud
    Senior Member GA Jet's Avatar
    May 2010
    My SST is a 454 and I love it. My Rebel is a 455 and after I use it as a test bed for a few other 455s i have been cleaning up I will be switching that Rebel to a 454. You wont miss that olds! You can put more RPMs on a stock 454 without having to worry as much about running your bottom end dry like you do in the 455s
    Over and above a driveline , water inlets and outlets, exaust and mounts you likley need a pan if you BBC doesn't have on or came from a door slammer , pan depth cant exceed 7 3/4 to maybe 8" (pan rail to lowest part) Tom
