what impeller
Results 1 to 9 of 9
what impeller
    valley springs, ca
    Default what impeller
    i have a spectra 20 with a 12jc jet. has a mild 460 ford in it. needs a rebuild in pump any recommendations on size of impeller i should use. I'm sure its a stock pump and has a loader in it. ( I bought it this way) the boat planes good and mid throttle it seems the motor is to free and don't have much load against it. If i smack full throttle the rpm shoot up and the boat does go but top end isn't to much. I use this for a cruiser and not anything else.
    Kingman/Golden Vly, Az
    Quote Originally Posted by sangerfan76 View Post
    talk to Tom at JBP, he will fix you rite up with everything you need (re-build parts, impeller, etc)...just sayin' my .02 cents
    FastRat
    Dec 2010
    Sapulpa ok
    aa if u just cruz
    Senior Member gregb's Avatar
    Redondo
    I'd find out what's in it and what kind of shape it's actually in before deciding. It is however always better to start with one that's too big, you can always have it cut down. I'd start with at least an A for your application.
    Jan 2010
    Medford, Oregon
    I have a spectra 20 also! About ready to overhaul my pump and Tom set me up with an AA impeller. I have a complete stock 455 and berkeley pump.
    Jul 2009
    Do you know what grate you have???
    At what RPM is the motor making max HP at? What RPM will it turn now?
    valley springs, ca
    I don't know what grate I have. I'm more impressed as many reply's I get here. I think I can tackle this rebuild . How do i know what one is in it? will the impeller be stamped? for my application will aluminum be OK ? you guys are awsome
    The "mild 460" and Spectra 20 will probably like an "A" or even an "AA" for what your using it for and if that 460 is in the 350 HP range its doubtfull it would see much benefit from a loader (depending on what loader is in it now and how its trimmed) chances are from what you describe the jet could simply use some "freshening" Tom
