What to do to make this Impeller fit my pump
Results 1 to 3 of 3
    Sep 2009
    Chicago, IL
    Default What to do to make this Impeller fit my pump
    Early Dominator Impeller
    Wear ring skirt diameter = 7.215" (.010" undersized)
    Wear ring skirt width = .800"
    I have a JE Berkley Pump. What do I need to machine down? how much?
    What wear ring would I need?
    Shell Knob, MO
    We make a wear ring for that application. Give me a ring. 417-858-8616
    Duane HTP
    California
    Over and above the appropriate wear ring, you will need to remove/machine the stuffer ring from the back side of the impeller to fit the Berkeley bowl.
