to pcv or not...?
Results 1 to 14 of 18
to pcv or not...?
    Sep 2009
    Red Mountain, Az
    Default to pcv or not...?
    I am thinking about just doing two breathers on my new 600 horse BBC and eliminating pcv. Anyone doing this in a closed engine compartment. Am I going to have oil mist everywhere? Let me know what your running and if it works. My cam is a .650 lift with a 850 holley dp. Big rect. Heads and powerflow exhaust.
    I would consider having both up front then ran to a puke tank....that should keep it from spittin. I have a closed with a pcv on the rear side and a reg breather on the front....I replace it at least 1-2 times a season. Watch out for the fumes...I just saw this pic...
    Made In The Shade
    Custom Window Tinting
    Sep 2008
    Yuma, Az
    you'll end up with a little oil, but being it is a closed engine compartment, it won't go everywhere. you can get a puke tank or taller breathers to help with the problem.
    boatless....
    I did a single PCV only system on a stock bbc. It was blowing oil out the dipstick tube. Gen 6 motor designed for a closed crancase system originally. Added breather in the valve cover and no more blowing oil. So I guess what I'm saying is even a stock engine needs to have the cranck case breath some way. If you eliminate PCV you better have decent VC breathers.
    Maple Ridge B.C. Canada
    another option
    just sayin
    MD
    no pcv no problem no mess 540 bbc
    Anaheim Hills
    Quote Originally Posted by jayman View Post
    600Hp in that beast? haha... I'm glad to see your having fun with the boat!
    Dennis
    Denton, TX
    Dennis
    You have been MIA for a while!
    Welcome back
    Senior Member jet460's Avatar
    Mar 2010
    Modesto, Ca.
    Why would anyone not run some sort of PCV?
    Without PCV your oil would be contaminated with gas in a very short time.
    Gas doesn't make a very good lubricant.
    $.02
    100 years from now, none of this will matter.
    No PCV for me either, just a set of breathers plumbed up to the carb pan.
    The Man cordog009's Avatar
    East Texas
    PCV works for what it's intended for. I don't really care about having oil film being put into the intake manifold. A guy could always get one of those little air/oil separators that you use on air compressors to remove the oil out of the air. We had to do that on several LSx motors because they were sucking oil mist from the valve covers into the TB. That fixed the problem, and the pcv still worked like planned. You'd be surprised how much oil gets past those pcv valves and goes straight into the manifold or carb.
    1984 Youngblood TX-19 SOLD
    I have never had mine drip a drop either. The pan evac to the headers is a good idea too. I would like to get around to that one day.lol
    Not splitting hairs but breathers in the valve covers or evac tubes to the headers are all types of crank case venting. Emission reduction was the reason to use a PCV valve and recycle the hydro carbons produced by heating the engine oil. In a performance application a good set of breathers usually does just fine. Point is to let the crank case vent and not build pressure. Now if you want to go all out, put a vacuum pump set up on your engine for that last little bit of HP.
    Default If you run open breathers and PCV the PCV doesn't work
    PCV is designed to vacuum the crankcase into the intake manifold - smog stuff. By adding a breather vent you eliminate the possibility of vacuum. Waste of time you by passed the design
