BBC Alternator
Results 1 to 6 of 6
BBC Alternator
    83 Crusader - 468 BBC SNiC's Avatar
    Apr 2011
    Sweet Home Alabama
    Default BBC Alternator
    Running a BBC and I am swapping out the 3 wire alternator to a 1 wire setup.
    What size and brand alt would you suggest?
    The engine is not covered....
    TIA
    Kingman/Golden Vly, Az
    Quote Originally Posted by SNiC View Post
    TIA
    FWIW...just convert your present Alt over to a 1 wire!!! ...do a search on here...there is a topic on how to do it ...just sayin' my .02 cents
    FastRat
    Apr 2011
    Sweet Home Alabama
    FastRat
    Thanks, but the the current one has some problems from unknown issues, I am wanting to start fresh, gauges, alt, battery....
    Sep 2008
    Yuma, Az
    it depends on if you have a booming stereo, 10 guages, or a 1000hp motor.
    if you have none of the above, a stock bbc alt. will work just fine. if you have a cd player, a few speakers, 5 guages and a mild motor, pick up a 80-100 amp alt and it will work fine.
    boatless....
    Shell Knob, MO
    This will do the job. I recommend putting the smaller Moroso Crankshaft pully on so you don't have to turn the alternator so fast all the time. It's not necessary in a boat.
    Tuff Stuff 7127NA Tuff Stuff Chrome Alternators
    Duane HTP
    East coast electric.
