need throttle stop idea for stringer pedal?
Results 1 to 6 of 6
    Atlanta TX
    Default need throttle stop idea for stringer pedal?
    anyone got any pics or ideas for throttle stop to keep pedal from going down too far on a stringer mounted foot pedal ?
    Kingman/Golden Vly, Az
    Quote Originally Posted by cpjet View Post
    just make yourself a wedge out of wood the size you need for how far you want the pedal to go down & glass it to the floor! ...just my suggestion
    FastRat
    I dont have one on my daytona. On a flat bottom k boat I had I took a piece of angle iron. drilled a hole and tacked a nut on it...bolted it to the stringer in front of the go pedal. Then by spinning the bolt in and out it was adjustable....once I golt it just right I double nutted it to keep it from moving. Looked a little ghetto but it worked well. If I remember right widowmaker made a sweet one.
    Atlanta TX
    I had one kinda similar with adjustable nut on my CP but it wasnt a stringer mount pedal & was alot simler to do.....Widowmaker you got any pics ?
    San Diego, CA
    Here you go. I took a solid chunk of 2" x 1" aluminum
    Boat 405.
    Atlanta TX
    Thanks Widowmaker , that's just what I needed.
