The New Hi-Helix Impellers ... ???
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 14 of 56
    Owner/Crew Chief 1/4 Miler's Avatar
    Rural Missouri
    Default The New Hi-Helix Impellers ... ???
    I'm interested in everyone's opinions ... who's running them, who Prep'd them for you and how are they performing for you versus the impellers you've been using in the past .....
    Reason I'm asking is we're 'redoing some pump things' and I'd appreciate your input .....
    Quote Originally Posted by 1/4 Miler View Post
    havent tried one myself. then again, they look real similar to an Aggressor.
    so when will the Mamba be back at the track?
    TRG
    TRG is offline
    Senior Member TRG's Avatar
    I have wondered about this same deal for a few years now, Ive hear that they perform very well, and other say they are turds, hope this is an informale debat and not the one that ends up in the can!
    TRG
    Rural Missouri
    Quote Originally Posted by TRG View Post
    ... , hope this is an informale debat and not the one that ends up in the can!
    TRG
    So do I ... I have confidence, some at least or, should I say Hopes that we've all progressed to the point of the Evolution of our discussions about Jet Pumps/Drives where we can discuss the engineering of the workings of pumps in a constructive way ... We'll see.
    The 'Black Mamba' will be back on 'The Rope' with Mike DRIVING as soon as I can complete the modifications I have underway are done, when our Crew decides they want to go and We can Afford It ... Gas to Ming and, Back is .....
    TRG
    TRG is offline
    hell of a drive for you huh? How long does it take you? seems like the KDBA would be a far closer track wouldnt it?
    Rural Missouri
    The boats running out of Phoenix now which is still a long drive to Bakersfield/Ming.
    southwindsforsure justsquirtin's Avatar
    Jul 2009
    rio linda calif
    im runnin one in my placecraft with a blown 540-does just fine-good low end pull it seems-still learnin with the power plant=need to make some adjustments in the shims
    okie, lake Texoma
    If you have an engine that will make 2000+ hp and dont want to spin it 8000+ rpms then I dont think that there's any other alternative is there?
    H8-2-W8
    [email protected] first pass
    TRG
    Todd if the economy hadn't taken such a dump for us two yrs ago I'd have some info for you guy's. With the economy and the engine needing a serious rebuild just haven't been able to do it. I got a HI-Helix "A" two yrs ago and was going to run it against my current MPD "B" with both radar gun acceleration info( you might recall my radar gun can plug into a laptop and give you time/speed and speed/distance readings) and GPS at 330', 660' and 1,000 ft info.
    My plan still is to run it compared to the current MPD "B" that spins 6,200 off the bottle ( 825hp absorbed), run the Hi-Helix out of the box to see what it does and then send it to MPD and trim it to let it spin 6,600 off the bottle and re-test and make the info available. If my "ship comes in" this year it's high on my list of things to do.
    After this rebuild the engine will have a bit more umph, I expect it to pull a bit harder.
    Sucks being broke.
    S CP
    TRG
    TRG is offline
    Just envelope the fact that were all broke Obeezie! it gets easier when you let that small fact go! I have trimmed fat where I can, and believe it or not, river trips were made once I did this! Hope your ship comes into port this year bud! the Imp. test would be some good info!
    okie, lake Texoma
    I have back to back experience just this morning with comparison from going from a AA AMT 9" Impellar to a 9" Hi-Helix and let me tell you, theres no comparison. If you have the HP to turn one ,then certainly by all means go with the Hi-Helix.
    H8-2-W8
    TRG
    TRG is offline
    Default Its not holding water Haas...
    any sort of data with your testing bud??
    Senior Member Futs's Avatar
    Orange CA, Big River
    Read his engine thread. There are a few videos as well.
    okie, lake Texoma
    Just what was recorded with the camera that I had on the guages.
    I dont normaly promote "seat of the pants" tuning but there was such a dramatic difference in the pull from one to the other that it was just night & day. Not to mention the large drop in rpms.
    H8-2-W8
