oil leaks through dip stick
Results 1 to 14 of 19
    Oct 2010
    Default oil leaks through dip stick
    after running the boat for a while oil comes up from the dip stick .what could it be???its been doing this since i bought it its just a mess at the end of the day. 460 milled heads .baby cam..what could it be??
    The Man cordog009's Avatar
    East Texas
    What kind of breather setup do you have?
    1984 Youngblood TX-19 SOLD
    Oct 2010
    one that runs from the head to carb also where i put oil it has a filter under it..this boat is heavy i want to race a jet ski and beat it what do i need to do i have the only jet boat here where im from south texas do i need a smaller craft or a pump rebuild???
    Quote Originally Posted by ATTITUDE ADJUSTER View Post
    Several things come to mind the worst being "crankcase pressure" from "blowby" (worn pistons/rings excess clearance etc , I'd do a wet dry compression test and cylinder leakdown test , but also and overfilled crankcase along with several other factors could cause this Tom
    Screamin SeaMonkees Schi-502's Avatar
    Vacaville, California
    Thumbs up
    Your distributor is on the wrong end of the engine!
    Let's see more pictures.
ID:	113757   Click image for larger version.
ID:	113758   Click image for larger version.
ID:	113759   Click image for larger version.
ID:	113760   Click image for larger version.
    Loose, the Dogs of War!
    Orlando.FL
    I put a piece of hose on the dipstick tube then push the dipstick in.
    I have a breather on the front and the pcv on the back. I leave my dip off with a black rubber vent block off on the sleeve. Just keep your dip in the boat somewhere to check oil every now and then.
    Made In The Shade
    Custom Window Tinting
    okie, lake Texoma
    Quote Originally Posted by Schiada 201 View Post
    A straight sparkplug boot works well for that but this works better
    Amazon.com: Moroso 25973 Twist Lock Engine Oil Dipstick Universal: Automotive
    H8-2-W8
    [email protected] first pass
    odfirefighter
    Jul 2010
    i had the same problem with my 460 in my sanger when i first got the boat last year. and im pretty sure it was caused by excessive crank pressure from blowby. the motor turned out to be pretty worn out when i pulled it this winter to rebuild it. now it is no longer a problem with the fresh rebuild. not sure if this is what your problem is but it was in my case. good luck
    Oct 2010
    so i check all the small stuff then if it still does it do a compresion test..at wot it goes to about 60 psi....
    High Performance Marine ARS Marine's Avatar
    Feb 2009
    Morris,Illinois
    60 ? On all 8 cylinders??
    Senior Member fourtznme's Avatar
    It is your Rings
    Murrieta / Needles Marina Park
    Jan 2011
    Mickleton, New Jersey
    it's dead
    East Texas
    Does your oil smell like fuel?
