front seat base
Results 1 to 11 of 11
front seat base
    seattle
    Default front seat base
    just replaced my floor and glassed it in. i have always had problems with my front seats being loose. they are lagged to the floor. because my floor is so low in the boat-i can only lag 1/2 the base because the other 1/2 is over the bottom of my hull. this is the stock setup.
    my question is can i build new bases and fiberglass them in so my front seats are bullet proof?????
    pros and cons of glassin bases in??????????
Name:	work'n on boat.jpg
    Glass them in....you can always grind it out if you go another direction.
    Made In The Shade
    Custom Window Tinting
    LAID IN MEXICO
    santa paula, ca
    Default seat base's
    build nice sturdy seat bases, and glass them to the floor. through bolt the seats to the seat bases. lag bolts will always work loose, or pull out. lag bolts are a really shitty way to bolt almost anything together in a boat. if you can, always through bolt everything.
    Pink Taco Reagan's Avatar
    Santa Clarita, California, United States
    X2 on thru bolting
    Heres some seat mounts we added to a 1/4 stringer Challenger boat were rigging now The Glassed plywood boxes were rotted , there a combo of 2/3 2/16 aluminum and 2 x4 Clear fir Tom
    Aug 2010
    after i finished my new floor i attacked my seats...
    made the seat bases and glassed em down onto the floor (pulled back the carpet), they're pretty damn strong.
    made seat frames:
    all upholstered!
    then i just made some brackets in the corners and bolted em to the brackets so i could take em in/out if i needed. cut some holes so i can take the seat bottoms out and i have a little bit of storage underneath.
    Senior Member GA Jet's Avatar
    May 2010
    Quote Originally Posted by ka0tyk View Post
    made seat frames:
    all upholstered!
    Man I love those seats! I might hafta steal your plan here
    seattle
    tom,
    where is a good place to shop for those metal front buckets your use'n??
    i am always on a budget...
    any and all websites would be appreciated...
    tryin to make up my mind on building all three and havin them upolstered, or buyin metal buckets and just buildin the bench............
    Senior Member Futs's Avatar
    Orange CA, Big River
    Quote Originally Posted by 1975sleekcraft View Post
    tom,
    Those are fiberglass front buckets. I think Tom sells them as well as alot of other around here.
    seattle
    Default $
    how much do them buckets go for????
    tom,
    Was alsleep at the wheel , the front Buckets are Fiberglass we have rear benchs now too and we sell them please check your Pms Thanks Tom
