Place Diverter Cylinder: Is there a under $100.00 alternative
Results 1 to 14 of 24
    Senior Member N2GLOCK's Avatar
    Oct 2010
    Default Place Diverter Cylinder: Is there a under $100.00 alternative
    I need to replace mine due to the fact that it leaks bad. I removed it and attempted to open it with zero luck (this thing is not meant to be seviced) I've looked for used units with zero luck also. I've been looking around, and they all seem to be north of $100.00 which seems to be a little steep for the nature of the part. Does anyone know of a less expensive alternative? Possibly a unit made by another manafacturer that will fit? Any help would be appreciated
    Senior Member slow67's Avatar
    DFW
    Quote Originally Posted by N2GLOCK View Post
    They look like dual acting pneumatic cylinders.
    look at WW granger they have a cylinder that is identical for about $30
    #55
    Lookin' for answers. Pizzy's Avatar
    Tucson, AZ
    Hey Outlaw do you have the part number or maybe can post a link to the page on Graingers site for said part? I looked all over that site and didn't see anything. Anymore info you could give is greatly appreciated.
    What's the point of growing up if you can't act childish once in a while?
    Mar 2011
    Quote Originally Posted by Pizzy View Post
    search pneumatic cylinders, took me sum searching to find them
    Tucson, AZ
    Thanks Yuma!
    Dallas, TX
    That one says"air" not "hydraulic". Will it work?
    put one on my last boat 5 years ago, still working
    #55
    Dallas, TX
    Guess that answers that. LOL.
    Apr 2009
    SW Ohio
    I realize this is slightly OT to the original post but I have been wanting a cheaper alternative to the entire hydraulic system. The cable + lever isnt that cheap when buying new either. So if air cylinders work for hydraulic what about using air solenoids as well?
    The cylinder I saw that looked identical was made by Bimba if memory is correct. They are available all over the place - grainger, mcmaster carr, probably about any industrial supply place locally.
    Quote Originally Posted by slim pickens View Post
    I would think the air would compress and allow the diverter to move
    #55
    Senior Member Futs's Avatar
    Orange CA, Big River
    Thats fine if you just want total up and total down. Can't regulate inbetween with an air solenoid.
    TRG
    TRG is offline
    Senior Member TRG's Avatar
    Diverter stop for up, and stack 5/16" washers on the cylinder for down, seems to work for my deal.
