454 BB...What kind of oil?
Results 1 to 14 of 16
    Member TooSober's Avatar
    Lake Forest, ca
    Default 454 BB...What kind of oil?
    It is a stock motor and i was wondering what kind oil to use? (both motor and for the Jet-Berkley). Also after the boat has been sitting for just over a year it fired right up and sounds good.
    But is there any maintenance like spark plugs, oil change, ect...that I need to replace or change? Thanks in advance for your help
    Kingman/Golden Vly, Az
    Quote Originally Posted by TooSober View Post
    you need to start reading threads posted in the forums!...the subject of oil for the motor & pump has been covered many many times! ...also...maintenance tips have been covered! ...just do a search for what you want to know ...just sayin' my .02 cents
    FastRat
    Lake Forest, ca
    Sorry i did look but i was unable to find what i was looking for. I will look a little deeper
    tell us more about your engine, remember jets run under load at all times, so spend the $$ for a good oil and filter.
    #55
    Lake Forest, ca
    it is a 454 BB Hardin marine. (stock)
    bullhead city
    by synthetic, whatever your favorite brand is, it will be worth it in the long run
    Feb 2011
    Wash.
    Use banana oil.
    Arcadia CA
    I've read a lot of the threads...I have heard good things about Amsoil.
    Mar 2010
    Clarksville, TN
    I'm a Mobil 1 fan 15-50 fully syn
    x2 have run mobil one for years in the race boat and personal boat, have had great success out of it.
    Chantilly Va.
    Quote Originally Posted by johnray069 View Post
    Me Too-Me Too!!!
    Lake Forest, ca
    Now that i got the engine oil taken care of, can you guys help me out on what type of grease or oil i need for the Berkeley Jet. I am familiar with nozzle for the grease gun but unsure what to use, also how do i change out the oil in the bowl. Thanks for all the help!!!
    Sep 2008
    Yuma, Az
    use 90-wt gear oil for the bowl. unless you think there is something wrong with the oil, it should be fine. if you used it after you parked it for the last year then you probably dont have much in the bowl.
    boatless....
    TRG
    TRG is offline
    Senior Member TRG's Avatar
    Valvoline VR-1 50W
