engine/pump spacing
Results 1 to 14 of 17
engine/pump spacing
    Retired Air Force Master Sergeant's Avatar
    Lake Havasu
    Default engine/pump spacing
    How much space should be allowed for pump flex within the shaft between the pump and the engine?
    Ladera Ranch
    Pretty sure I went with 3/16".
    B1 Racing cs19's Avatar
    Lake Havasu
    I installed an engine w/ what I am guessing not enough space and ruined my engine as it pushed the crank into the side of the block. All the rod bearings were spun, it is trashed.
    It would typically wipe out the thrust, then maybe send trash through the engine and wipe out the rods etc. How's the thrust?
    Lake Havasu
    Crank, rods and pistons all unusable. Block has scores in it from the crank but is OK. Am thinking a new 540. 572 or 604?
    Concord, CA
    Default ruined
    This is on the new motor?
    Jerry
    Senior Member stoker2001's Avatar
    Folsom,Ca
    Quote Originally Posted by billet racing View Post
    Jerry
    Dont ask...
    we need sponsership funds fast
    Hey Jerry,come up to CFW this Sat for test and tune,weather should be great
    Whacker Smacker M/E #561 IHBA "first looser"champ 2006&2007&Sportsman Driver of the Year
    Senior Member lbhsbz's Avatar
    Long Beach
    go with 3/16"-1/4" to be safe......I set up my last boat with about .060", and it leaned on the crank. You're gonna have some hull flex as well as deflection in the thrust bearing under load.
    It probably goes with out saying but make sure your dl isnt twisted....you may have it set ok...but it may be hanging up on a twisted shaft. Just throwin it out there.
    Lake Havasu
    Jerry
    Yes. A lot of money wasted on such a seemingly small detail. Have a bigger engine in works though
    Member E Rock's Avatar
    Jun 2010
    Tulsa OK
    on topic and ignorant question. can you put enough space between motor and pump, to disconnect the drive line for dry starts?
    if you guys are only using .060 or 1/4 inch, how in the world would you have enough room to disconnect the drive line without sliding the motor forward? or is that just that..... you have rails and slide the motor forward?
    in other words, if i have just an h-bar with a slip yoke going into the pump, can I space the two apart enough to disconnect from the flywheel and slide the driveline back enough to clear? for dry start purposes.
    Concord, CA
    Default spacing
    Quote Originally Posted by E Rock View Post
    Yes you can. I did that one year at the drags. Every time I had to warm up the motor, disconnect the driveline covers and the ujoint. Pain in the ash.
    Jerry
    Concord, CA
    Default new engine
    Quote Originally Posted by Master Sergeant View Post
    I knew I'd get along with you for some reason. Bigger is always better. But your wife would not ride in the boat as it is, how is she going to go faster?
    Jerry
