What circuits need to be fused
    Las Vegas, Nv
    Default What circuits need to be fused
    I am wireing the boat and am confused about what circuits need to be fused?
    Can some one please explain? ....Hal
    Hal I ran a 50 amp to feed up to the front(switch) then run circuit breakers on everything
    except the starter/solenoid
    #55
    Aug 2010
    i used one of these.
    One Fast Wacker
    Jul 2010
    Atascadero, Ca.
    Every thing you don't want to "Let the Smoke Out" of. Usually protection is twice the size of running load. 7 amp load 15 amp fuse. I use a switch like a Perko to completely disconnect battery power. Feed the starter and the fuse panel off of it.
