bowl oil barf
bowl oil barf
    Senior Member sleekcraft137's Avatar
    Star, ID
    Default bowl oil barf
    so i hooked up my boat to the water hose and noticed that the bowl barfed its oil out when it was running. Bowl bearing seal?
    And the new project begins!
    Quote Originally Posted by sleekcraft137 View Post
    If you have oil coming from the bowl its likely that the seal may be fouled or damaged , yes Tom
    Star, ID
    i'll pm you on mon to order the seal and bowl bearings
    Star, ID
    So.......i pulled the bowl off and discovered that there was NO bowl bearing seal!! Also the bowl was siliconed to the pump and had no gasket as well as no gasket from the bowl to the nozzle(2 piece bowl). So after a call to jet boat performance i should have what I need to get this pump working.
    Thanks Tom for your help on this!!
