tunnel ram 850s
Results 1 to 14 of 16
tunnel ram 850s
    Apr 2010
    Rocklin, Calif.
    Cool tunnel ram 850s
    How would you guys jet a pair of QFT 850s on a 498 chev. 14.2 comp.solid-roller 366 cam lift [email protected] 050, 261 - lobe center 112 ? Should I jet them sqaure ? also air bleeds, power valves ? What I've got now is air bleeds-29+67 jets 70+80 power valves 3.5 it's still fat...but I don't want to burn it down..I run at campfar west 130 ft.above sea level Thanks...
    Senior Member Pattymelt18's Avatar
    Call C&j engineering 5622290222. Talk to John. Great people
    Senior Member StressExpress's Avatar
    Feb 2009
    Menifee, Ca.
    X2 c&j
    Promoting pollution Smog Pump's Avatar
    Sep 2010
    Pumpkin Center, CA
    I doubt you need a 7-8 Power Valve. Switch to a 3, 35 or maybe a 4. No more than that. They're supposed to OPEN at the number and I doubt with that cam you have 7-8 pinches of vacuum(which means they're OPEN at idle).
    You MAY have other problems, but I'd certainly start there.
    SORRY. Just reread your post. Your Jets are 70-80, not your Power valves. Your OK there. You may need to stagger jet for your T-Ram to show consistency.
    Pump
    show your tits topless000's Avatar
    Your carbs are sideways on tunnel ram? First you need to lock out linkage on secondaries to make them one to one. Pull the power valves out and put in blockers. i would start out jets at 80 square. if she bogs out of the hole bump up the discharge nozzles one or two sizes.. do you have picks?
    Southwest corner AR
    Quote Originally Posted by topless000 View Post
    X2!
    Square it up and see what it does!
    WT
    WFL Crew!!!
    Apr 2010
    Rocklin, Calif.
    Cool
    Thanks guys..heres the deal,I bought these for the 498, they never were right, when I had joey grose dyno it we couldnt get enough air through them, left alot of power on the tabel,so I shiped them to bob oliver (he did a great job on my 660s) he recalliberated them and there better...but this thing should crackel not blubber..he told me when removing power valves you must richen primarys 10 up..this isn't an allout race deal...but I'll pick a few fights....so I guess what I'm asking is anybodys setup close to mine what are you running...I will give C+J a call thanks again
    Apr 2010
    Rocklin, Calif.
    Cool
    jetboatcowboy has shared a video with you on YouTube:
    tuning in a tunnelram with 2 @ 850 proforms
    By the way, did you know you can rent movies from YouTube? Check it out now: youtube.com/movies.
    © 2011 YouTube, LLC
    Iuka, Mississippi 38852
    Call Quickfuel and ask to speak to Zach Baker. He`ll put you on the right track. 270-793-0900 x223 . Carburetors and Carburetor Parts for Drag Racing and Street Rods - Quick Fuel Technology
    Apr 2010
    Rocklin, Calif.
    [QUOTE=Richard Till;1434394]Call Quickfuel and ask to speak to Zach Baker. He`ll put you on the right track. 270-793-0900 x223 . Carburetors and Carburetor Parts for Drag Racing and Street Rods - Quick Fuel Technology[/QUO
    Actually Ron @ Topless Racing cleaned these up for my...he was a little stumped also...maybe he'll chime in
    Apr 2010
    Rocklin, Calif.
    Cool
    Ok got the problem fixed...the quick-fuels are landfill now, I've been chaseing my tail for 6 YEARS trying to figure this out. I have called C&J john basicly told me I was taking up his time...so for 10 mins. I sent him 10$..cash..he can KISS MY ASS. These pieces of shit have been back to quick-fuel twice, once to a guy in nevada..and twice to Ron Baker...Ron got these going better than anyone,but he knew they weret right...THANKS RON...so I called John Avery he told me he wouldnt touch them,ther parts are made in CHINA ..............SOOOOO now I've got REAL carb's comming from Chuck Nuytten...I'll keep you posted.......
    Apr 2010
    Rocklin, Calif.
    Quote Originally Posted by Richard Till View Post
    I did talk to Zack and Scott and some other inbread...yea what help
    it was just a suggestion my friend. sorry it didn`t work out for ya.
    Southwest corner AR
    Nuytten is good but high$$$$$ I have one of his carbs and it works well! Some of the carb builders do have problems with T Rams! They are not as easy either! Post up the performance of the new setup when you are done!
    WT
    WFL Crew!!!
