Pump Bowl oil ???
Pump Bowl oil ???
    Junior Member Prime's Avatar
    Apr 2011
    Texarkana, TX
    Default Pump Bowl oil ???
    Gentleman, I am fairly new to the Jetboat experiance and could use some help. I own a jetboat with a Dominator pump. My question is,
    I keep reading on maintaining a jetpum and came across where it said that the Bowl oils needs to be checked and filled to proper level?
    Now does my pump have one?
    If it does Where are the plugs located?
    It may seen like a dumb question and this topic may have been beat to death, but I am sorry but I am lost. Thank yall and I greatly appreciate any help.
    corona calif
    Default Dominator pump
    Depending on the year of your pump you will either have a bowl with open glacier bearings which you will be able to see on the exit side of the bowl or a zerk fitting which will allow you to grease the tail shaft . With all of the late model Dominators and American Turbines they all have grease fittings on the tail shaft area. Berkeleys have an oil bath tail shaft area.
    The Man cordog009's Avatar
    East Texas
    Prime I see you're just up the road in Txk
    1984 Youngblood TX-19 SOLD
    Apr 2011
    Texarkana, TX
    Shoemaker, Thank you. I do have a later Dominator and I have found the Greeze Zerks, I just wanted to make sure I had all my bases cover.
    And yes brother I am just up the road, as a matter of fact I had the pleasure of meeting some of your WFLC brothers just the other day Hopefully we can meet next time yall have a outting.
