Engine mount
Results 1 to 8 of 8
Engine mount
    Retired Air Force Master Sergeant's Avatar
    Lake Havasu
    Default Engine mount
    I have had my 650hp engine in here for years w/ out a problem but now am planning an upgrade. How much hp would you think this frame/mounts good for? How could it be strengthened?
ID:	114608   Click image for larger version.
ID:	114609   Click image for larger version.
ID:	114610   Click image for larger version.
    The Man cordog009's Avatar
    East Texas
    That looks pretty good to me. You might could add some aluminum plate on the outside of the stringers, maybe add some cutouts in them to remove some weight. A pump brace could be added in while the engine is out as well.
    1984 Youngblood TX-19 SOLD
    Lake Havasu
    Who could fab a good pump brace in the Sacramento CA area?
    southwindsforsure justsquirtin's Avatar
    Jul 2009
    rio linda calif
    sac engineering
    Concord, CA
    Default mounts
    X2. A solid strip of aluminum in place of the washers. Still use the washers, to pread the load on the aluminum. As for adding cutouts, it adds beauty, but would save less weight than a can o beer.
    Jerry
    bullhead city
    how much hp, longer rails, any cross bracing by your seat
    Lake Havasu
    Quote Originally Posted by hihosilver View Post
    850hp yes, cross bracing at seat
    Senior Member watergun4u's Avatar
    Visalia, California, United States
    Quote Originally Posted by Master Sergeant View Post
    x2 on the pump brace,and the stringer plate on the out side of the stringers! Ironman here on the boards can hook you up with a pump brace and the stringer plates! if you want his # let me know! great guy ,great work, and great prices!
    You can get ahold of Tom at JBP and he has the stuff you need as well and is a great guy to do biz with!
