Shift adjustment
Results 1 to 2 of 2
Shift adjustment
    Member Katanna's Avatar
    Jun 2010
    Howell Mi.
    Default Shift adjustment
    Does anyone have a picture of a place diverter in the nuetral shift position they could post? Just installed a new diverter and cables and not sure where to start with the shift adjustment.
    Ladera Ranch
    I don't have a pic, but it should be in the middle of its range of travel. There are adjustments at both ends of the cable. You have to play with it to get it right.
    Also, make sure that the cable end nearest the control is mounted in such a way that you are taking advantage of the full range of motion.
