Will this work to pressure tap 2 gages
    May 2010
    Discovery Bay, CA
    Default Will this work to pressure tap 2 gages
    Will this work to add 2 inlet pressure gages on pump to meassure upper and lower pump inlet pressures and check loader input
    I am ordering from McMaster.com
    4003K712
    Stainless Steel-Case Gauge +/-2% Accuracy 2-1/2" Dial, 1/4" NPT Male Center Back, 0-60 PSI
    today$20.36 each40.722ft.
    5112K62
    Extra-Flex Nylon Tubing .106" ID, 5/32" OD,.025" Wall Thk, Semi-Clear White
    today.25 ft.12.503each
    51495K269
    Nckl-Pltd Brass Push-to-Connect Tube Fitting Adapter for 5/32" Tube OD X 1/4" NPT Female Pipe
    today5.48 each10.964each
    51495K212
    Nckl-Pltd Brass Push-to-Connect Tube Fitting Swvl 90 Deg Elbow for 5/32" Tube OD X 1/8" NPT Male
    today2.95 each5.905
    Break Out AnotherThousand
    May 2010
    Discovery Bay, CA
    bump
    Impeachment! 75 TX's Avatar
    Culver City, Ca
    looks like the same stuff I used for my taps. Except the gauge. Is it liquid filled? I used an Autometer.
    You gonna get 2 gauges or use a 3way valve and 1 gauge?
    May 2010
    Discovery Bay, CA
    Quote Originally Posted by 75 TX View Post
    I just figured 2 gauges then I can monitor upper and lower at the same time
    Thanks for the reply
