How Far Back To Set Intake
Results 1 to 6 of 6
    El Cajon
    Default How Far Back To Set Intake
    I Have a 19' Eliminator Daytona, how far back should I set the intake? Right now if i were to put a pop off valve on it, it would be very close to clearing the back of the boat.
    The Man cordog009's Avatar
    East Texas
    I'd think if you are far enough back to clear a popoff, you're about as far back as you might want to go.
    1984 Youngblood TX-19 SOLD
    El Cajon
    I'am removing the intake and if there is a benefit to moving it back further i would like to know
    Senior Member toon's Avatar
    Littleton,Co
    Put a post up in Greg Shoemaker's section or call him.
    Positive Vibration Dread Pirate of Humboldt's Avatar
    Humboldt
    Here's a pic of mine. Sounds like yours is where it should be.
    Concord, CA
    Default set back
    If your planning on using a popoff valve, consider setting back just far enouph to clear it. Woul dkeep you from carving out the transom at a later date. Keep in mind you may need an additional 3/8" for the backing plate. This should leave your inlet under the hull still. You don't want to have the inlet opening any further than the rear most point on your bottom. That's what I've been told by the ones who know.
    Jerry
