Do Bassett Headers Make a Difference
Results 1 to 13 of 13
    Senior Member Areyouliving's Avatar
    Apr 2009
    SacRiver
    Default Do Bassett Headers Make a Difference
    On a fairly mild 460 BBF are a set of Bassett thru transom headers going to make much of a difference in performance? Currently running Hardin Marine logs.
    Cas
    Cas is offline
    Angry American Cas's Avatar
    to answer your question, yes, they will make a difference. If you are going from logs/risers, there's a chance you could get an additional 300 rpm but there are many variables that come into play.
    Carb, intake, cam, heads, valve size all play a part....even the type of log that's on the engine now.
    My engine ended up with about 300 rpms more over the Hardin Marine logs with 2-7/8" risers but only about 100 over the Harmon logs and risers that were hogged out to about 3-1/4". Big block chevy though.
    Apr 2009
    SacRiver
    Cool thats what I was wondering. FWIW D0ve heads, stock valves, roller rocker, just shy of 10-1 compression, flat tappet cam, tunnel ram with dual holley 450's.
    Any midrange or are all gains going to be top end? And if it matters these are thru transom headers.
    Cas
    Cas is offline
    yes, mine are thru transom and yes, I did get better throttle response over the Hardins. I don't remember if it was on here or on the old Hot Boat forums where I posted up the numbers each time I made a change. I'm thinking it was on HB and most of it was info in regards to carb and intake changes, some about the exhaust.
    Since not every engine is the same, results will vary but also keep in mind that just because the engine gets more rpm, it doesn't necessarily mean the boat will pick up speed. That's a whole other area of discussion in regards to the hull itself.
    Sep 2008
    OC, CA
    Quote Originally Posted by Areyouliving View Post
    Did you do any port work on the exhaust?
    Apr 2009
    SacRiver
    Quote Originally Posted by cp562 View Post
    No port work.
    Cas thanks for your input. Much appreciated
    Sep 2008
    OC, CA
    No port work.
    Unless you do some port work on the intake & exhaust, the gains going to Bassetts won't be worth the cost IMO.
    Cas
    Cas is offline
    No port work.
    I just did a little searching, are you thinking about putting them on the Hallett or did you sell it and putting them on a different boat?
    If it's the Hallett, keep in mind Bassett TT's shouldn't be put under an engine cover, they get way too hot for that. Basically, you would need to lose the cover so you have an open engine. Also, that Hallett is a well built hull that's on the heavy side so you may not see real mph gains in the top end.
    Apr 2009
    SacRiver
    They would be going on the Hallett. I was concerned about the engine cover. I was thinking I would use some header wrap. After what you guys are saying it sounds like maybe I should just stick with the stockers?
    Thanks CP for your input as well.
    I really thought since I would have less water flowing thru the exhaust that It would help out a lot.
    Cas
    Cas is offline
    If it were me, I'd leave it alone also. Those Halletts are great looking boats in original form.
    Aug 2010
    go center risers...
    Apr 2009
    SacRiver
    Ok would center rise be better than the logs?
    Quote Originally Posted by ka0tyk View Post
    go center risers...
    ANYTHING is better then logs.......
