The Poncho breaths again
Results 1 to 8 of 8
    Dallas, TX
    Default The Poncho breaths again
    Still need to do the water lines and install the transom plugs but other than that it's about buttoned up.
    Glendale Arizona
    This is following the block repair? Congrats on getting her going again.
    Dallas, TX
    The block repair became a rebuild. After I stitched up the water jacked I found the main webs were busted. These were totally unrelated issues. Turns out the casting I had is known for weak main webs. Fortunately I found the cracked main webs when I was fixing a leaky oil pan and not by windowed the block. The rotating assembly was OK.
    Member neverenuf's Avatar
    North Texas
    Sounds great!
    Apr 2009
    SW Ohio
    Wait, you REPAIRED this?? Holy f'n peaches... It must be extremely difficult to sit down or walk with the size of the pair you got! j/k
    Sounds great, nice work. Its good to see something different than the same old BBC once in a while.
    Ladera Ranch
    You found a new block, right? Hopefully one that is not prone to cracking?
    Dallas, TX
    Quote Originally Posted by slim pickens View Post
    No. LOL. I didn't fix the busted mains. I fixed a crack in the water jacket THEN I found the busted mains so I got a new block. Here is a link to the water jacket repair. See posts #13 & #14. Thanks for the compliment on the unique power plant.
    http://www.performanceboats.com/jet-...-n-stitch.html
    Dallas, TX
    Exactly. I found an earlier 67 year model block. It is the casting number that most Pontiac experts agree is as good as a Pontiac 400 block gets without going after market. Just for the sake of getting the info out, the castings ending in 557 are the ones with the weaker main webs. With the early block sitting next to my 557 block it is obvious to the naked eye that the ***557 blocks have less material in the main webs. The 557 blocks were produced starting ~1975.
