[Question] Replacing floor?
Results 1 to 5 of 5
Replacing floor?
    Member ocelot's Avatar
    Mar 2010
    Default Replacing floor?
    I'm replacing the floor in my Southwind Formula 1. I have new floor glassed in with matt so far 18 in long 10 in wide, overlapping 6 in, first layer. I staggerd second layer joints,right now 2 layers down soooo i plan on woven next layer,but the original floor was was installed with one sheet of heavy woven sheet. the way i have done it the overlapped joints are either 3 or 4 layers.. seems to me that this is stronger than original. I was thinking about not even laying the woven down. Any thoughts would be appreciated. Thanks
    Menominee, mi UP
    Aug 2009
    Menominee, mi
    sounds like your good to go
    Aug 2010
    seems a bit overkill. i did one layer of mat with a 4" overlap to the hull with 1/2" plywood covered in resin on all sides and epoxied to the floor. i knew i was going to be glassing seat bases to the floor so i wanted a little extra strength. i could prolly pick up the boat by my seat bases now. heh.
    Oct 2010
    661 So. Cal.
    You are good to go if it was me I would not put the woven in it, it's plenty strong as it is
    Mar 2010
    Thanks fellas thats what i was thinkn, now for the bulkhead.
