Gents, anybody have pics of their throttle cable bracket?
Results 1 to 14 of 17
    Silverdale, Washington
    Default Gents, anybody have pics of their throttle cable bracket?
    I havent cared for the bracket I have for my throttle cable (single 4bbl) and was curious of what some of you guys are using on your engines.
    Thanks in advance...........john
    Dallas, TX
    Got mine from Tom @JBP. I am happy with it. My cable pushes from the front but the bracket can be flipped for cables that pull from the rear.
    I used a similar bracket but built my own cable bracket from a piece of 1/2" aluminum
    it has a set screw to hold the cable and is drilled and tapped for the mounting screws
    #55
    Senior Member nick's Avatar
    Fullerton & Water Wheel Resort
    here is what i used, it started as a "scoop mount bracket" from jegs, they are orignally desinged to hold a big fiberglass scoop but i run a small polished aluminum one. I wantd something that would go under the carb and have vertical supports I could connect to the scoop to hold it straight. But in my search i found this thing, it was good for me because it also had a throttle cable integrated.
    Works for me, and I thought it was cool. I still need to modify it a bit but it's working good thus far. Here is the link; JEGS Performance Products 55015 JEGS Scoop Mount and Tray for Dragsters
    Here are a couple pics, one from the front and one from the back, sorry they are not the best quality.
Name:	carb front.jpg
    Default carb brackett
    might want to check jegs and summitt they both have similiar brackets that i have used that for those that want or need also incorporate an adjustable return spring bracket on them and have the cable retainer with them. .02
    Dallas, TX
    Quote Originally Posted by johnray069 View Post
    Just FYI, I tried one from Jegs first and it would not work for me. My cable pushes from the front. The brackets from Jegs would not clear the accelerator pump arm when turned that direction.
    Lake Havasu az.
    Mine had same problem....a little clearance work with a grinder fixed that puppy right up........
    Being able to buy parts that bolt right on takes all the fun out of it
    Not to jack the thread but can anybody explain the purpose of a push throttle as opposed to a pull throttle?
    Aside from maybe being able to reach down and pull the pedal up
    if the throttle sticks........if my throttle sticks my first move is go for
    the kill switch....
    I can't think of anything else that uses a cable to push the throttle open.......cables usually pull the load, spring return.
    Sheriff Joe Arpaio
    When I switched to a domi...I had the same accelerator clearance issue dealio. I just spun 1/2" nuts to hold the carb down....then put the bracket on top of the nuts...followed by another pair of nuts. I didn't see any other way around it.
    Thanks everyone. Looks like most, except for Paul are running the cable from the front. I've been running mine from the back which with a Holley puts the linkage way up there and the run of the mill brackets available local make the attachment too far back to reach. Gonna have to check out those combo ones like you guys posted up. They may work fine. Thanks again........john
    Dec 2010
    Sapulpa ok
    Quote Originally Posted by Sold honda.bought hondo View Post
    the kill switch....
    The push is popular due to clearance between the pedal and bulkhead
    John mine was originally from the front
    I bought a longer cable and flipped the throttle body around so I could come in from the back to avoid the blower belt
    I got my bracket from Eddie marine
    If you want me to build one of the cable holders let me know
    Sent from my iPhone
    #55
    Impeachment! 75 TX's Avatar
    Culver City, Ca
    The Earth
    Blog Entries
    24
    The side plate we make will flip either direction for push or pull. No slots either (a stiffness thing)
