OIL CHANGE...how to.....
Results 1 to 14 of 21
    Senior Member Mouzer's Avatar
    corona ca
    Default OIL CHANGE...how to.....
    sitting for 3 yrs.460 ford.Drained the oil out the oil ext hose through the pump (PLUG DRAIN) first got a lil sludge then clean oil,(filter oil was clean)but before i put new oil back in,any suggestion on what i could pour in to clean the pan of any sludge...and let run right back out...to loosen up or clean out the pan.thanx mouz
    slower than you Suckin-n-Pumpin's Avatar
    dixon ca
    1 gallon diesel fuel, take it for a tow then drain. thats how I got old oil out and it worked like a charm
    East Side
    I have used diesel fuel with good results as well. You might want to considet pulling the pan depending on how bad it is.
    corona ca
    Thanks will do! there was'nt much ,it could have been in the drain hose.
    ....like warm apple pie RaceFace's Avatar
    Mission Viejo
    You usually want to change the oil while its warm. Oil has suspension properties in it and the junk would be in the oil, not on the bottom of the oil pan and it would drain with the oil.
    You might want to consider putting new oil in. Running it for a day on the water and draining it while its still warm. It will help 'flush' it out and get that crap off the bottom of the oil pan.
    Thats how I would handle it.
    Race
    MI
    Run a quart of ATF in it for a day.
    MD
    Quote Originally Posted by sanger rat View Post
    That works great for me as well.
    corona ca
    thanks will do both.deisel then new oil w/atf and will run it at elsinore monday for a hr or so and bring home and drain,put new oil in and filter ....
    "It's HONDO, honey" Kyle's Avatar
    AZ, Queen Creek
    Can i get a amen The diesel fuel can be kinda risky you cant rev the motor, only let idel for like ten minutes. And honestly if it hasn't run for say a long time and it is nasty oil the diesel and old oil is like sand on main bearings. ATF is still oil and is has inhibitors that keep it from burning and contains good solvents to keep the valve body in the trans clean.
    corona ca
    thanks..the diesel i wont start just pour in and drive around the block and drain...thanks
    Senior Member snake321's Avatar
    Middletown, Connecticut, United States
    Ahhhhh the hell with it, just sell it Mouz....
    YOU LIE!!!!!!!!!!!
    Quote Originally Posted by Ultra26 # 1 View Post
    I've been known to be a jackass a time or two.
    Senior Member cave's Avatar
    Mesa, AZ
    Quote Originally Posted by snake321 View Post
    Takin it home
    Crank case "cleaners" of any kind are very risky IMHO. they do thier job of removing deposits very well and you run the risk of some of that sediment being left in the low reaches of the pan (hard to effectivly drain on a boat) only to be drawn up to the screen . When I get a vehicle with a concern of sludge or varnish etc I do several short interval oil changes with a good detergent oil . Those oils have properties which surround dirt and deposit particles and safley carry them off . my 02 Tom
    *recently worked with an Atty on a deal where a quick lube joint sold him a crankcase clean , vehicle only made it from Ventura to Bakes ,the residual junk that didn't drain, plugged the oil screen about 90% ,Smoked the lower end
    Tacoma Wa
    I'm with you Tom. The last thing you want to do is take those carbon deposits, sludge, or whatever out of suspension and have them floating around the engine. Seems to me that might be an expensive problem. Imagine if one of those carbon deposits made it up next to the piston skirt and cylinder wall. Carbon is hard stuff and is usually what makes up sludge.
    ~Brian
