Center Rise or Bassett Exhaust
    Senior Member Areyouliving's Avatar
    Apr 2009
    SacRiver
    Default Center Rise or Bassett Exhaust
    Ok, a few weeks ago I posted a question about whether or not Bassett thru transom headers would be a good upgrade for my boat. I got some great answers, thank you guys. As it turned out without some port work to those heads the Bassetts really were not going to be much of an advantage. So they are getting some work done.
    Here's where I am at now. I have the option to run aluminum center rise headers or Bassett thru transom. The center rise have a 3.5 inch output and the bassetts have a 4". The Bassetts are water injected.
    My setup is 471 Ford, D0ve heads with some port work, roller rockers, dual tunnel ram with 450 Holleys, bottom end is tight, not sure of the cam installed, all in a 19' Mini Daycruiser.
    I'd really like to know which exhaust will benefit this boat the most. Cas and CP I'm looking froward to you're input again here.
    If this belongs in another spot on the forum please let me know where,
    Bill
    Apr 2009
    SacRiver
    Anyone
    Bakersfield
    If you're planning on keeping the engine cover, you can't do the injected Bassetts, you'll have to $tep up to Lightnings or CMI. Go with the IMCO center rise deals, a friend of mine has some on his Hallett like yours and they look great.
    Aug 2010
    im partial to my center rise. they changed the sound a lot too. lot deeper.
    performance wise i dunno. i just hear anything is better than logs and snails.
