adjusting nuetral
Results 1 to 14 of 24
adjusting nuetral
    Senior Member 79sleek's Avatar
    May 2011
    Wyoming
    Default adjusting nuetral
    How to adjust foward reverse and nuetral on berkley 12 jg not really any nuetral reverse good forward good just nuetral. Bucket needs to come furthar down in nuetral position but how to adjust it?
    The Man cordog009's Avatar
    East Texas
    Quote Originally Posted by 79sleek View Post
    You might try putting the handle in the neutral position and see where the reverse bucket is. If you're going forward while in neutral try and adjust the bucket down a half turn or so on the cable and see where that puts you at.
    1984 Youngblood TX-19 SOLD
    May 2011
    Wyoming
    When in nuetral the bucket is like 3/4 open almost wide how do you adjust the cable to go down?assuming it should be like 1/2 to 3/4 closed for nuetral any pics may help. Do you take the pen out of the nut and move those nuts up and down? Or somewhere else?
    May 2011
    Wyoming
    These nuts on the lower cable attached to the bucket? If so messed with them today won't move far enough? Or the top ones where the go through that arm or both? Thanks that will help a bunch especialy for pulling skiers
    Member Katanna's Avatar
    Jun 2010
    Howell Mi.
    If you cant move the ones at the bucket far enough, you will have to make the adjustment at the other end of the cable where it attaches to the shifter.
    Are you using a lever with detents?
    Good way to get in trouble IMO
    Sent from my iPhone
    #55
    Wait! Jet Boats have nuetral ???
    May 2011
    Wyoming
    Only the ones with SKIERS on the back.LOL I KNOW usualy never need it. Detents? My lever is free flowing normal on jet boats I assume detents are the levers used in outboards and I/O the ones u have to pull the lever to engage fowrd or reverse. Mine hase the morse I believe thanks ill try to adjust it at the lever today appriciate all the help.
    The Good mrjoshua's Avatar
    Aug 2010
    Albuquerque NM
    What about at the handle? Can't you loosen the set screw and rotate it where you want it and the press the control handle back on?
    East Texas
    Yea you might see if you can get some more adjustment at the handle. Maybe that'll give you some room to move it around.
    Kingman/Golden Vly, Az
    i agree...i have "never" seen a Jet boat with a neutral!!!!....i think the "experts" would agree that you cant get the bucket into the position, so that the water will flow rite, so the boat doesnt move!...i could be wrong & if so, i would like to see how its done!...just sayin' my .02 cents
    FastRat
    East Texas
    FastRat
    Seems like mine have all tended to go forward some when the handle was straight up, wasn't ever anything I was worried enough about because I could move the handle more to reverse and stop it pretty much. I think he's just trying to find the sweet spot where it won't move as much either direction when in the neutral (not forward or reverse) position.
    FastRat
    Not sayin one might not find some "nuetral middle ground" , My FIL for example had his "adjusted" to where he would leave it tie nose and tail to thier dock and "let it warm up" it would still drag the dock fore or aft a bit , Jet boats: reverse is marginal and they back up like a fork lift
    Senior Member wolfie's Avatar
    Jet boat "neutral" adjustment!
