i cant get my #!%#(!* pump out!
Results 1 to 14 of 17
    Aug 2010
    Default i cant get my #!%#(!* pump out!
    ive tried everything... when i took it out last time it wasnt nearly this difficult. i used regular silicone to seal it and i had a tiiiiiiny weep at idle but a big squirt leak when i was on my way...
    it moves... but it doesnt release. i picked the whole boat off the trailer with just silicone holding it in... what the hell!
    the whole point of all this is to use this plate to be able to get the seal nice and tight...
    im hoping i can get it out, get everything cleaned up and sealed with 3m 5200 marine silicone so i never have to mess with it again...
    any suggestions on what to try next?
    Wet
    Wet is offline
    East Hampton, CT
    I don't recommend resealing with 5200. When done right, silicone works perfectly.
    The Earth
    Blog Entries
    24
    If you use 5200 you will Never get apart again easily. Use marine silicone. When used properly it seals and is removable, although tough. No comparison to 5200 tough though (to take apart).
    Senior Member cave's Avatar
    Mesa, AZ
    Its tough to get the silicon to release. I used carb spry to get a corner to lift just enough to get fishing string through. It was a bitach. Once the fishing line was through it cut the silicon like butta. A thin blade to get through the silicon anywhere you can .
    Takin it home
    The Earth
    Blog Entries
    24
    guitar strings or very fine stranded wire also work if you can get it in.
    Ladera Ranch
    5200 has no business being used on a boat IMO.
    X's 2 , I'm sure this stuff has its place , but Oh my God to have to work with it fresh or cured
    Cas
    Cas is offline
    Angry American Cas's Avatar
    Quote Originally Posted by ka0tyk View Post
    A 2x4 between the hull and the pump always worked well for me but don't push with constant pressure, use a bouncing and/or a wiggling motion. Just make sure you have something under the pump for when it lets loose. I always used a moving pad folded up so it was about 4" thick. Also, as others said, no on the 5200.
    That plate came out great looking! Good job on the polishing!
    Senior Member XClutchboy725's Avatar
    Alta Loma, CA
    I recently removed the transom adapter from my boat. I found that using wedges, driven in slowly with a hammer worked best. If you use this method, you'll notice that you can drive the wege in just enough to add stress to the silicone. After a few seconds, you can hear the silicone letting go. Then you can drive the wedge in a bit more and wait some more. Eventually, the silicone let's loose when pulled apart.
    The guitar string and fishing line ideas sound good too!
    Jeff
    Aug 2010
    Quote Originally Posted by XClutchboy725 View Post
    Jeff
    yeah when i had it up in the air i can hear the silicone stretching and breaking but then it would stop. when i had the back of the boat 1" off the trailer i figured it was time to stop with that method. heh. a buddy of mine mentioned going up from underneath with a coat hanger or something thin and stabbing at the silicone to break it up. ill nix the 5200 i guess in case i ever have to do this again. i guess ill just toss a bead of it on the company toilet seat for good laughs instead.
    Aug 2010
    thank you for the plate, i hope everything works great with it. i just gave it a quick go around on the buffer. hopefully once i get a run out of it ill start cleaning everything up. that transom pic made me sad with all the dust and dirt in it. i swear i keep my bilge clean!
    California
    Not sure if pulling up on the pump is going to accomplish much, the cherry picker is however a good idea to help support the jet if your doing it solo. You might try removing either your ride plate or the trailer roller to allow the pump to move down some.
    Senior Member Double A's Avatar
    Apr 2010
    Yakima, Washington
    Yeah, down is the way to go. Chain it downward by the "end" of the pump for leverage. Just like strapping your boat down on the transom.
    Aug 2010
    Quote Originally Posted by Double A View Post
    ill give it a try going down. last night i was standing on top of it and bouncing the whole trailer up and down and nothin....
