43BC cable
Results 1 to 14 of 30
43BC cable
    MD
    Default 43BC cable
    I'm looking for a good HD 43BC cable.
    I have tryed the Teleflex Cable, lasted two seasons then comes apart
    Does anyone make a HD 43BC cable???????
    I sell hundreds of those (T/Flx)every season and have very few problems with them ,send it to me with a copy reciept of purchase (doesnt matter where bought) I'll replace it UPS charges only Tom
    Tacoma Wa
    Dayum dude, your like the Santa of Performanceboats.com.
    Thanks 'Daze ,just belive in the product and stand behind it !
    (when you comming up again?)
    MD
    Tom.... Thanks I can't find the reciept.
    I did send an email to company that I got it from to see if they can do anything.
    Can you PM me a price on a 43BC cable CC69213
    Thanks Don
    MD
    Back to looking for a good cable it did it again
    Rex replaced it under warranty last time
    Would like to know why this keeps doing this
    happened in 08 and now 09
    Send it in I'll replace it Tom
    Senior Member Fonz69's Avatar
    Frozen Tundra, WI
    Wow!
    How is it routed on your boat to have so many problems?
    Is it making some very tight bends somewhere?
    Morgan Hill
    Your problem is a piss poor alignment at the shift lever, sometimes you need to space oout the clamp area to get it to line up properly, also you may have too long of an arm on the shifter (called a bell crank), this put unneeded stress on the cable end and breaks the outer wires retainong the jacket.
    The bigges mistake I see is that people try to wire tie the living crap out of the cable to the wire harness and the clamps in the hull, you must allow the housing of the cable to move for at least the first couple feet of cable on each end...
    I have seen this before and the cause is almost always the same. Get it aligned and let it move around.
    BTW, Tom, very big of you.
    GT
    MD
    GT
    Tom Thanks... As I have said befor you are one hell of a stand up guy
    at this point I just sent an email to Mike (Rex) as he is the one I got it from
    GT thanks for some good ideas
    I will try to take some pics of my routing of the cable tonight.
    The outer wire just pulled out of the clamp did not brake the wires
    If I understand you right the first bend that comes from the shifter
    my be to tight and causing the inter cable to push the outer wire out of it's clamp
    This is on my Place Diverter the shifter clamps all look good, nice and straight
    Thanks just the same let me know !
    re "the cables" I probably didn't decribe well when I say "geometry" I'm refering to the imaginary "line" between the anchor point and the terminal end as well (this will cause damage at the cable end psleeve/tube) Also too tight of a radius from the cable anchor point for or aft is tough on the plastic jacket . The first is hard on the cable tube/sleeve and the second is tough on the cable jacket where its attached to the end anchors Tom
    Senior Member watergun4u's Avatar
    Visalia, California, United States
    If it is happening on the bucket end, you may need a longer cable to take the travel of the diverter,, be sure to have a good size bend coming out of the transom to the bucket, So when the diverter is all the way down you are not putting any stress on the cable!
    MD
    will get better pic
    A Morse cable was on the boat when I got it, and the date on the cable was 06-99
    I replace it do to cracking of the out case in 06. The Morse cable was thicker than the new
    cable
    Senior Member HammerDown's Avatar
    The Right Coast/SE-PA
    Talking
    Soaker, 0ver 10 years on my REX cables...you're obviously doing something wrong
    Also, my diverter handle is stringer mounted (no bends)...I like it between my legs
    [SIGPIC][img]https://www.performanceboats.com/gallery/data/500/medium/06-30-11_1234.jpg[/img][/SIGPIC]
