What to use to get Registration stickers off my boat!!
Results 1 to 14 of 16
    Default What to use to get Registration stickers off my boat!!
    Trying to get my Registration stickers off my boat, the old michigan ones, and its a bitch!!
    I got a heat gun and razor blades and its slow and painfull, no to mention im scared to scratch the gel
    I also want to remove the name off the back of the boat which is made up of the same type of sticker.
    Is there a spray chemical that can help me out?
    Thanks again!
    Santa Clarita
    WD-40 and some patience
    whats a goodtime cost? Nixonnow's Avatar
    Feb 2011
    Fort Mohave, Arizona
    3M makes an adhesive remover. Works great.
    Bakersfield
    Try Goof Off, you can get it @ The Deep Homo and Lowe's
    Led
    Led is offline
    Senior Member Led's Avatar
    Jul 2010
    It is worth your time to be patient, the heat gun basically separates the material from the adhesive and leaves at the gunk on the boat. I like to use Goo-Gone available at Walmart to remove the glue. I worked at sign shop for years and this is the best product for any type of surface, without worrying about it eating into your paint. They have some better stuff but you have to be real careful with it.
    If the numbers are not so old and stiff you can get a corner up with a blade and then just peel it off and the adhesive should come with. If they are being stubborn then a heat gun is your best bet and get to soaking the glue with the remover.
    Nov 2009
    3M one can to remove the old sticker, a different can that removes the adhesive. way easy!
    Mar 2010
    Clarksville, TN
    I have used Goop Off, pretty good stuff And have used oven cleaner but be careful
    Senior Member harley222's Avatar
    Sep 2009
    Use rubbing alcohol and a plastic squeege, just go slow and work the alcohol under the sticker it will come right off....and the alcohol works great to take the glue off once you get the sticker off...
    okie, lake Texoma
    The 3M is adhesive remover is designed to take adhesive off of freshly pained surfaces without damage. Works great. I use it on all kinds of stuff.
    H8-2-W8
    [email protected] first pass
    Senior Member bp298's Avatar
    LHC
    for the glue, goo gone is great stuff, but i don't have te patience for it. many years ago, a detailer suggested lacquer thinner to get really nasty road grime off the gel. been using it ever since. takes care of sticker glue very quickly and cleanly... just get a rag wet with it and go to work...
    Sep 2008
    OC, CA
    Blender, if your planning on changing the name of the boat, you need to purge its name from the Ledger of the Deep and from Posidons memory so the boat dosen't have bad luck.
    Senior Member MBMoseBilt's Avatar
    Quote Originally Posted by cp562 View Post
    I hate to agree with CP562 but he is 100% correct. You should never change the name of a boat without the Ledger of the Deep being purged.
    Renaming Your Boat - BoatSafe.com
    Im not changing the name, i'm just making it smaller, its going to be on the back of the boat between the 2 pissers.
    I know all about the bad luck name deal and how to get around it
    Social Mrs.Racer277's Avatar
    Bakersfield, LHC
    Thanks again!
    Is it just adhesive??? May sound crazy but I use Pure Citrus Spray. (orange air freshner) takes sticky price tag adhesive right off. Worth a try.
    We used oven cleaner to get our boat name off. Did nothing to our gel.
