Need a steering cable
Results 1 to 8 of 8
    Senior Member motomattox's Avatar
    Apr 2011
    Default Need a steering cable
    Hey guys, any one know where I can find this steering cable? It is a rack and pinion style, cable measures 14 ft, almost 15ft to the center of the rack ( see pic). No number or marking left on the cable. Would love to find a good used one from someone if possible?? 78 Bahner 18ft with Berkely pump and place diverter
Name:	steering cable.jpg
    Sep 2008
    Yuma, Az
    rex marine
    cp marine
    jetboatperformance.com
    Please check your PMs Tom
    Aug 2010
    on the end of the cable plastic part theres a number, which includes the length. ie mine was ssc15416, so a teleflex ssc 16' steering cable. in my case it was just as cheap to purchase the entire rack and pinion + cable kit, it was like an extra $10. my rack had a little bit of play in it so i figured i might as well.
    Apr 2011
    I will be calling. Thanks...and I should have called in the first place. You have always done me right!
    Apr 2011
    Quote Originally Posted by ka0tyk View Post
    Absolutely right. Ill be ordering through Jet Boat Performance. My hub is corroded and looks terrible, and cable prices hace been within 30 BUCKS, not even sure they would work
    Senior Member Fonz69's Avatar
    Frozen Tundra, WI
    I might have a good used one if your interested?
    $10 and the shipping and its yours if it will work.
    Let me know and I will measure it and find the numbers but it came out of a jet boat I parted out a while back and saved it because it was like new.
    Just checked the cable and it says 18' on it
    Apr 2011
    Installed my cables today! Tom, you are the man! I cannot believe how fast you got those here. Thanks again. Literally less than 24 hrs of ordering, I was installing. Awesome!
